Pitman Arm Woes
Old Jan 26, 2011 | 07:06 PM
DonW's Avatar
DonW
Default Pitman Arm Woes
So far I've bent two pitman arm pullers and it remains stuck. I took the steering box and put it in my press with two 1/4 inch steel plates under the arm, essentially dangling the box under the press with the arm through the lower press bar, and pressed on the worm drive and one of the plates started to bend. Any ideas? Freaking thing is really stuck. If I heat the arm at the taper will it help release? I have about 1/4 inch between the arm and box. Trying to avoid banging the K-rap out of it with a pickle fork. Thanks for any suggestions
Old Jan 26, 2011 | 07:33 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I'd give attempting to expand it with heat a go.
Old Jan 26, 2011 | 07:46 PM
Sean82's Avatar
Sean82
this is easier on the car...
attach the puller to the pitman arm.
tighten up the puller until it is very tight. hit the end of the puller with a large hammer. You do not need to hit it very hard.
tighten puller, hit with hammer, tighten puller, hit with hammer.
Repeat till cold
Old Jan 27, 2011 | 12:00 AM
macx's Avatar
macx
Just FYI: Most normal steel will expand about 80% of it's total max expansion at 300 deg F.
Old Jan 27, 2011 | 01:14 AM
snoopykissedlucy's Avatar
snoopykissedlucy
I say place in freezer overnight.
Next day, whip out the torch and heat the arm.
Then use your third puller!
Old Jan 27, 2011 | 01:47 AM
my 76 ray's Avatar
my 76 ray
I had to use an oxy/acetylene torch to heat mine almost red hot before it came off.
Old Jan 27, 2011 | 09:07 AM
thegazman's Avatar
thegazman
Default thegazman
Old Jan 27, 2011 | 01:22 PM
Kevin68's Avatar
Kevin68
I did this to get the ball stud separated from the pitman arm (only I dipped it in ice water). Use anti-sieze grease when reassembling.
To Pitman Arm Woes
