Manual trans question
Old Jan 28, 2011 | 06:19 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Default Manual trans question
A club member contacted me last night and asked if I knew of any drain plug kits for a manual trans. His car is a 73 SB with a 4 speed.
First I have to ask, does the manual trans have a drain plug from the factory? All of my Vettes have been autos. I know they make kits for autos.
If no kit has anyone installed a drain plug on their own? Where did you put it and how did you do it?
Thanks.
Old Jan 28, 2011 | 07:41 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
All Muncies with casting #3925661 had them, as do all M22 rockcrushers. To add one to a case without a drain plug one would have to drill and tap the blank boss near the bottom of the case and install the proper pipe-threaded plug.
Old Jan 28, 2011 | 07:43 PM
Duke94's Avatar
Duke94
Should be a plug on the bottom to drain and one on the side to fill. All the Vette parts suppliers sell the plugs.
Gary
Here's a BW T-10, Muncie should be the same.
Old Jan 28, 2011 | 08:06 PM
Tally Ho's Avatar
Tally Ho
Thanks for info and pics. I'll pass it along.
To Manual trans question
