manually shift an auto transmission?
Old Jan 29, 2011 | 11:13 AM
elle88's Avatar
elle88
Default manually shift an auto transmission?
I'm totally new to auto transmissions...because i owned only stick cars.
i have the chance to buy a nice 68 Camaro but it has a 3 speed auto trans. I will buy that only if i'm sure i can use the auto trans in manual mode in spirited driving ( frequent up downshift as i'm used with my stick corvette)
i've seen the car just in picture and i see that the trans handle ( a big handle on the tunnel) selects also position 1 ,2 and 3 . how do they work?
btw i've seen that parts suppliers sell valve bodies ( TCI and Hughes) that will allow the manual selection of gears.would they fit my requirements?
i would like some advises about
ah... what is "trans brake"?
Old Jan 29, 2011 | 11:36 AM
bluthundr's Avatar
bluthundr
I think you want a "Manual Valve Body" kit, which will turn your automatic transmission into basically a sequential manual gearbox.
Old Jan 29, 2011 | 02:47 PM
c3corvette77's Avatar
c3corvette77
you can shift a th350 manually. just put it to 1 at the light, when you get to where you want to shift move it to 2nd and so on. i manually shift mine all the time.
Old Jan 29, 2011 | 03:03 PM
Billysvette's Avatar
Billysvette
Yes you can with a nice shift kit,and the auto is quicker then 4 speed.Auto will win out every time at the track and street.And it is less stress to the car then the 4 speed,things wont break as much
Old Jan 29, 2011 | 03:06 PM
Timsride's Avatar
Timsride
The automatic wont be exactly the same as a standard, but can still be shifted manually. The trans brake that You ask about is used for drag racing, it basicaly allows You to rev the engine in gear. You can use the gas pedal to bring RPM as high as You want, then hit the button and Your gone.
Old Jan 29, 2011 | 03:10 PM
Scott Marzahl's Avatar
Scott Marzahl
Manual valve body kit for the trans. Trans Brakes are a drag strip thing to spool up the engine before you launch. Taken from the Art Carr site.
The Art Carr Rebel Brake has a quicker release, faster 60-foot times, and has a built in safety feature. The Rebel Brake has neutral in the reverse detent, so that when the transmission is shifted to reverse it is a neutral. To back up, shift into reverse and use the Trans brake button. Micro-switch button transmission brakes will give you an instant super launch. The quicker the launch the better the E.T.! All transmission brakes come with bolt-on valve body and solenoid. Transbrake buttons are also available.
Old Jan 29, 2011 | 03:13 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
True in most cases, but not nearly as fun to drive.
Just my opinion, your mileage may vary.
Old Jan 29, 2011 | 03:58 PM
elle88's Avatar
elle88
thanks everybody.
my only concern is that I think it would be easy when driving ( and shifting) fast to go from 1st gear to 3rd or, worst , from 3rd to 1st since i'm used to manual transmission and so to "throw in " the gear with straight force on the stick...
have to try...
Old Jan 29, 2011 | 04:29 PM
Vette5.5's Avatar
Vette5.5
Think you'd be happy installing a Trans-Go shift kit, as use these in all my automatic's with very good result's in the street/strip set up. Still full auto in the "D" selection, with firmer shift's and fast response for manual gear changes. If you're doing 100 mph and select first, first is what you're getting. Pretty inexpensive, and a very easy install on a TH350. You can also go full manual with these kit's.
Old Jan 29, 2011 | 04:38 PM
big454blockchevy's Avatar
big454blockchevy
Hopefully I am not moving out of topic here. but I have a '94Lt1 camaro with a 4l60e. It was upgraded with a billet servo , transgo shift kit. It shifted fine for about a year then all of a sudden it wouldn't move out of first if left in 3rd(D) or 4th od . So basically this tranny needs to be shifted manually or it doesn't move. It kind of feels like a manual valve body kit was installed . When I get to a stop light I start downshifting and eventually if I come to a complete stop I go to 1st then start up shifting as the rpms go up. It's been like this for 2yrs now and I honestly enjoy the shifting part of it. I have even run a 14.0x at 99 mph at the track with it like that.
Old Jan 29, 2011 | 07:10 PM
Manuel Azevedo's Avatar
Manuel Azevedo
First I do not think you would want a trans brake at all on the street. Each company's brake will be different in use but what they all do is lock the trans in forward and reverse at the same time, when you release the apply button it dumps the fluid from reverse and away you go! Your engine will not rev any higher than what the stall is of your converter. The full manual valve body is just that, it will apply any gear at any time you move the shifter unlike your stock set up which will not up shift no matter if you move the shifter or not depending on your speed/oil pressure in the trans has to meet a preset level before the shift will happen. As some others have brought up you will be just fine going with a good shift kit and call it a day!
Old Jan 29, 2011 | 09:07 PM
gkull's Avatar
gkull
TH350's can't handle much of a load. My highley modded one filled the pan with gear teeth. So i went to a 850 HP 700R4. I tried to road race with it and it was a waste of time.
My 700R4 had brutal fast shifts. So I had to learn to lift for and instant to keep from looping my Vette when shifting while turning. Down shifting while braking was also tricky to time the shift while braking. Because it was very easy to cause the rears to lock up. I pitched it sideways coming into turns quite often. That was even with my 9.5 inch lighter torque converter. Torque converters are like big heavy flywheels. they resist rpm change so it is easy to lock the rears on the down shift
The gear spacing on auto trannies is too big. Just three gears or possibly 4 with an OD. Auto trannies suck 25 or more HP just to run the pumps.
Real race cars don't use old auto trannies
Old Jan 30, 2011 | 06:51 AM
elle88's Avatar
elle88
Gkull
uhmmm....what you say is exhactly what i feared about auto trans. correct downshift is impossible due to wheel lock up. quite dangerous. i think i have to search for a manual transmission car anyway and forget autos. unfortunately all Camaro and Mustangs here in Italy ( and europe ) are mostly automatics
btw which the gear ratio of a th350?
Old Jan 30, 2011 | 09:22 AM
gkull's Avatar
gkull
TH350 2.52 1.52 1.00
I just read an article that a th350 burns up 35 hp. I went to a 4.11 to close up the gear spacing on my auto trannies.
I just had 355 ci and shifting over 7000 rpm with slicks is what filled the pan with metal teeth from my stronger sprag
With that in mind, there are a number of internal pieces that should be upgraded for applications transmitting approximately 400 lbs-ft of torque or more through the transmission. (The actual breaking point will depend on vehicle weight, gear ratio, traction and driving style.) Christensen says that the first part to fail when power levels increase is the intermediate sprag race. Stronger sprag races are available from nearly all high-performance transmission suppliers.
Old Jan 30, 2011 | 10:19 AM
ED69ray's Avatar
ED69ray
If you are used to a stick and want to engage in "spirited driving" don't waste your time with an automatic.
Biggest mistake I ever made was putting a TH350 back in my Camaro. Its sitting on the garage floor now and an M-20 is taking its place.
Auto's are great if you just want to cruise with a cup of coffee in hand or if you run full time at the strip - otherwise they suck
If its not a pristine original car, you could always convert it from auto to manual. Its pretty easy.
Good luck, Ed
Old Jan 31, 2011 | 12:06 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Try a look at "Gated" shifters.
Originally Posted by elle88
thanks everybody.
have to try...
Gkull
B&M has all kinds of auto shifters for street and race. I think the gated shifters could be fun as they allow u to bang the gears - have a reverse lockout too. I believe u can drive with shifting done automatically also if wanted. And their "Hammer" shifter looks great.
I just can't find one for the 4L60E in my Z28. B&M makes no shifters for electric auto trans. BTW my 4L60E has a 3.06 first gear and is basically a turbo 350 that shifts electrically - meaning steep first gears should be available for the turbo 350 (i think a manual 4L60E is called a 700R4 or something like that).
Give B&M a call (1-818-882-6422) and explain what u want.
cardo0
Old Feb 21, 2011 | 10:40 AM
Georgia_boy21's Avatar
Georgia_boy21
8th Gear
One good thing about autos is that can be very strong transmissions espicially the Turbo 400 and the torque convertor and fluid in it act as a cushion so your not placing high shock loads like a with a sticky highpressure clutch, I personally like both types, it really depends on how you set your vehicle up, Automatics do use power but they also give good launches. I would have a manual/automatic valve body installed.
Old Feb 21, 2011 | 01:37 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Good luck, Ed
I know you. You will not be happy with an automatic.
I think there is a bolt in T56 6 speed kit available for Camaros. Team it up with a 4.11 12 bolt. Now your talking.
Old Feb 21, 2011 | 02:08 PM
elle88's Avatar
elle88
I agree too , unfortunately...
i gave up with that auto Camaro . i need a stick car for sure , but can't go a for an auto to manual swap on that car, too expensive
To manually shift an auto transmission?
