I would go with the ol AC delco plug..if you still got a points distibutor go with the Acell points..they make a heavy set good for high rev..expensive but work great..I used the acell coil also..I noticed a change only after I changed the coil..the old one barely put out 15kv..new one is at around 35kv..big jump..I guess I am covering the whole tune up thing..oh and wires..only get a high quality set as they are a good bit of work to put in as they are under the valve cover style..
It's hard to beat AC, but for all intents and purposes as long as you buy the appropriate heat range for your application, it really doesn't much matter what brand. You don't need to buy the expensive, exotic and highly hyped brands...you're wasting your money. Unless your engine is built up or you have a specific problem you're addressing, a spark plug equivalent to original equipment is all you need.
I remember a friend who was both a street and drag strip racer told me he preferred Champions for a Chevy small block and AC for a big block.
Couldn't resist this one...I once did a mileage comparison as to which plug took the longest to oil foul when my leaking-intake Vette was using obscene amounts of oil. Between Champion, Autolite, and AC the AC's lasted the longest. Does that mean AC's are the best plug? I dunno. My old engine builder/ salt flats racer friend once told me that he preferred Champion because their white cadmium finish made them easier to read, but I've always heard others say that Champion's quality control was poor. I currently have AC's in my Pertronix-equipped 350 and they've been in there for 9 years and over 30,000 miles with no problems....hope this added to the cornfusion!
split fires. i been running the same set for a long time now with no problems. i saw they come stock in the zzfastburn crate motor so i gave them a go having fast burn heads.
I like the AC delco's too...
Note - different gap if yer running points ('74 was the last year with points ignition)...I converted my '74 to HEI so I run a .045 gap...
I bumped my gap up to. 40 since the coil puts out more zap..I thought HEI started in 76? Oh well..its hard to remeber what happened when..did you get the gear drive set up I have seen for the tach in the new HEI setup?
I run mainly NGK in everything I own. If I cannot get a NGK plug I use an AC Delco. I stick with copper unless it is my daily driver, which I use platnium since I do not like to change them much.
HEI started in '75....I converted mine..
Didn't get the tach drive....going to soon though...
NGK's The only plug I could take tot he track and still make it home without missing a beat. I did not like the bosch 4 electrode and Champions were the worst. AC is also a
good reliable plug.
You can buy bosche P+4 for the older peanut plug heads. The real value of multi tipped plugs is that you don't have to index them to unshroud the spark for best flame travel.
The super tips made out of platinum or iridium don't erode like junky common plugs
They also consistantly put out a small amount more HP on the dyno runs.
If you are running points and crap wires you might as well run crappy old 50 year old design plugs also!
They also consistantly put out a small amout of HP on the dyno runs.
Well I will take my 50 year old design and the 390 dyno hp I got..they work great if ya know how to set them up..is there something in the GM manual that talks about indexing plugs? I don't remember reading that in there.
Bosch Platinum +............not the multi prongs 2s and 4s........just the original single electrode ones. I've drag raced with them, an HEI and MSD super coil/box.
I don't have any experience with the multi-ground-electrode spark plugs, but when I want max performance, I use a plug with a single ground electrode, and even grind it back a bit to give the flame kernal every chance to expand and burn all the fuel.
I fail to see the logic of erecting a multi-pronged fence around the expanding flame kernal to improve flame propagation.
Larry, Your idea of grinding back the tip is a good one. Most high rpm race motor plugs jump from the center out to the side ground electrode.
A spark can jump from a small pointed object easiest. The bosche P+4 has a tiny center and tiny side electrodes. The smaller the point the more erosion resistant it has to be.
