81 Ring & Pinion
Old Feb 1, 2011 | 01:27 AM
BadBaran's Avatar
BadBaran
Default 81 Ring & Pinion
I sent my rear out to a local guy to get 3.55 gears put in. He called me yesterday and swine he can't find the right ring and pinion set. He said he tried 3 different sets and none fit. Does anyone know what kind I need and where I can get them.
Thanks for any help
Old Feb 1, 2011 | 01:38 AM
Buddy1980's Avatar
Buddy1980
Default 81 ring and pinion
I purchased a ring and pinion for my 80 at Randys (online), they seemed to have anything you would ever want. I got a 4.10 and a bearing and installation kit for the 80. Hope this helps.
Old Feb 1, 2011 | 08:44 AM
Nobody.'s Avatar
Nobody.
I have a new 3.73 that I KNOW will fit if you're interested. There are very few vendors that stock 80-82 Vette rear gears. I looked what felt like forever before I found the 3.73s that I have. I bought 2 sets and used 1 of them.
Old Feb 1, 2011 | 11:35 AM
Tom@Zip's Avatar
Tom@Zip
Platinum Supporting Vendor
80-82 Corvette C3 Differential Ring and Pinion
We offer several ratios for these diffs, and we have the 3.54 in stock.
Give me a call if you have any questions.
Tom 1-800-962-9632 ext 240.
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles | Corvette Parts Blog
Old Feb 1, 2011 | 12:15 PM
larryg3's Avatar
larryg3
I was about to say that there are no 3.55 for the 80 - 82 rear dif. I had a 3.54 put in mine.
You will like the difference really woke up the car.
Old Feb 1, 2011 | 04:45 PM
Nobody.'s Avatar
Nobody.
Tom, I gotta ask... what makes your 3.07 ratio so special that it costs $120 MORE than any other gear? Is that the 'replacement' gear that people buy the most?
Old Feb 2, 2011 | 01:31 AM
Gale Banks 80''s Avatar
Gale Banks 80'
I'd bet your shop was trying to use C4-Viper Super Dana 44 Gears in your C3 Dana 44. One would think they are the same but they are not.
Old Feb 2, 2011 | 10:40 AM
Zip Corvettes's Avatar
Zip Corvettes
I would like to day it is a super duty special gear, but it is no different from the other ones. The reason that it is more expensive is that is how it comes into us from the supplier. The reason they get more money for it is because it is a low quantity run gear vs. a 3.54 or 3.73 or 4.10 gear. So with less quantity the price goes up
Justin
Old Feb 2, 2011 | 03:39 PM
Rebelrob's Avatar
Rebelrob
I need to pull my receipts, but I think I got my 3:54 ring/pinion from Zips. Not sure.
Tom or Justin, where does Zips get their gear sets? Who and where is the manufacturer?
Thanks,
Old Feb 2, 2011 | 05:40 PM
alswagg's Avatar
alswagg
Think about this for a second. IF your mechanic can not even find the correct ring and pinion, do you really think he can set up the gear properly? I have bought several ring and pinions from Randy's Ring and Pinion, for our 4X4's. They are really good with supplying the correct parts. Note there are several special tools need to properly set up the pinion depth and carrier side brgs. Tooth patterns, and backlash must be set perfectly or gear whine will develope. Heck you can even send you carrier assy to Randy's and have them install the gears. They do it all the time. Al
Old Feb 2, 2011 | 06:43 PM
BadBaran's Avatar
BadBaran
He has set up rears before but does solid axle rears. He has never worked on vette rears before so I guess he didn't know the ring and pinion had to be different nor did I
Old Feb 5, 2011 | 02:23 AM
BadBaran's Avatar
BadBaran
Ill be ordering them from zip's. My mechanic said he called GM and they told him the gears were the same as a 10 bolt. So they sent him gears and they were wrong of course. Thanks GM
Old Feb 5, 2011 | 05:12 AM
gingerbreadman1977's Avatar
gingerbreadman1977
i would not use this mechanic either. gears are dime a dozen. i used motive gears in my 81 with the stock dana 44. and they were 355
To 81 Ring & Pinion
