How much are you guys paying for a new ZZ4 Rotating assy? These are basically a 4 bolt,. roller block, fitted with new cranks, pistons and rods. The brgs are installed for the cam, but no cam included. I am just wondering, as the ZZ4 rotating assy are what we install as a replacement block assy for Vortec Marine engines. Al
I know our cost of a ZZ4 rotating assy. I was just wondering what others are paying. $2,800 is pretty high. Anyone else? Like I said, no cam included or timing chain ect. Al
Al
Seems you have marine experience ... have question on Vortec Marine Gaskets.
I've installed marine INTAKE gaskets for 4.3 V6 Vortec ... gaskets are aluminum base w/ green silicone. Installed them in GMC truck ... Those are GREAT gaskets ... they have a GM part number (which I've since forgotten)
Question: Is there a GM equivalent alum-green silicone MARINE intake gasket for the iron head 5.7 V8 Vortec? Part number?
on rotating assembly ...a few around here have attempted to create their own look-alike crate motors (i.e GMPP x602) for regional crate motor restricted circle track racing. They found out the real-deal genuine GM cranks, powder rods & hyper pistons per x602 are TOO pricey! Pretty sure ZZ4 has same x688 rods.
Sorry, but I have not seen any aluminum framed intake manifold gaskets. The marine versions run so much cooler than the automotive versions. I do know Fel-Pro does make a version like you want. Not sure of the cost. As for the ZZ4 I rotating assy. Last summer I used 3 of these and was hoping to maybe get a better cost. But, I sell the rotating assy for less than $2,800.00 Al
<<SNIP>> As for the ZZ4 I rotating assy. Last summer I used 3 of these and was hoping to maybe get a better cost. But, I sell the rotating assy for less than $2,800.00 Al
Are you guys calling a short block a rotating assembly?
The rotating assy's I have been buying are the ZZ4 block, crank, rods, pistons ect. NO cam's. Some "short blocks" include a cam. The one's I buy do not. These are all externally ballanced engines also. When one is taken apart the pistons have a special coating on them. Black or dark charcoal in color. These are brand new from GM High Performance division. Ironically they come from Mexico. The last block assy I bought last fall was manufactured over two years ago. Al
Want a replacement partial engine for your ZZ-series engine? This partial engine includes the ZZ4’s forged steel crankshaft and comes with LT1-style pistons and connecting rods. It does not include the camshaft, cylinder heads, lifters, timing set, front cover, oil pump, oil pan, balancer, or flexplate. All parts needed to complete the engine assembly are available from your GM Performance Parts dealer.
