Converting SB to BB
Old Apr 11, 2002 | 11:36 AM
honaker's Avatar
honaker
Default Converting SB to BB
I think i'm going to get the BB for free(needs a rebuid, motor is locked up). If the motor checks out ok, i want to put it my 77.
I have a maual 4 speed.
What am I looking at replacing to put this BB in place of my SB. I know i'll need different motor mounts, but what about the clutch? Will the clutch linkage alignment still be ok.
:smash: :reddevil
Old Apr 12, 2002 | 02:33 PM
honaker's Avatar
honaker
Default Re: Converting SB to BB (honaker)
Now I know, one of you guys out there have done this, help me out please. :confused:
Old Apr 12, 2002 | 07:33 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
This has been talked about and documented several times before. If you do a search you should find lots of info in the archieves
Old Apr 12, 2002 | 11:55 PM
Mighty Mouse's Avatar
Mighty Mouse
Try looking under Swap to Big Block by Mighty Mouse 4/6/02. Then maybe instant message those that sound like they know what you need.Good Luck!!! :D
Old Apr 13, 2002 | 12:16 AM
Clai1's Avatar
Clai1
bence13_33 is doing it as we speak. :smash:
Old Apr 13, 2002 | 01:47 AM
Detroit Vette's Avatar
Detroit Vette
Well you are going to need to change to coil spring to a higher rate. Otherwise your going to risk rubbing your tires on the wheel wells.
Old Apr 13, 2002 | 09:01 AM
MassVette's Avatar
MassVette
Been done a lot....... clutch linkage setup is OK; flywheel is different (454 is externally balanced); need to use 11" clutch; mounts are OK; you need the 69-74 BB Corvette pulley setup, along with the short-neck water pump. Good luck.
Old Apr 13, 2002 | 09:37 AM
73-454's Avatar
73-454
Same question was asked in one of the Vette Mags the tech guy said forget-it to expensive to do properly he said cheaper to buy a big block vette
To Converting SB to BB
