Head Bolt Question
Old Feb 3, 2011 | 12:48 PM
DO2G's Avatar
DO2G
Default Head Bolt Question
Is using standard motor oil under the head of the bolt acceptable? Or, do I need ARP assembly lubricant?
I do have the ARP sealant for the threads.
Old Feb 3, 2011 | 03:32 PM
GeorgeS's Avatar
GeorgeS
I use ARP!
Old Feb 3, 2011 | 05:21 PM
brando1118's Avatar
brando1118
Do2g,
You need to use a sealant on all the head bolts so coolant doesn't creep up the threads and start to leak. I think some forum members had issues with the ARP sealant. Search for head bolt leaking coolant. You will find some hits on the subject.
Good luck.
Old Feb 3, 2011 | 08:20 PM
Indiancreek's Avatar
Indiancreek
Valco Co. makes a good thread sealer that I've used often. Can be gotten on line.
Old Feb 3, 2011 | 08:46 PM
LT1driver's Avatar
LT1driver
permatex #2 back in the day
Old Feb 3, 2011 | 09:01 PM
markids77's Avatar
markids77
If the torque spec calls for "wet" torque, I believe the place for that lube is on the threads themselves. A thread sealer would suffice, and I can't imagine that the drag of the bolt head against the head or thrust washer would influence final torque by much. I am prepared to get educated though!
sly vette's Avatar
sly vette
I would think any type of lube under the head of the bolt to obtain a accurate torque reading would be adequate. I use just a dab of assembly lube and smear it around the shoulder of the bolt and the washer when applicable.If I read your question accurately.
You didn't specify where the bolt is being installed.
Old Feb 3, 2011 | 11:48 PM
Solid LT1's Avatar
Solid LT1
Use the ARP thread sealant for proper torque values.
Link: http://www.jegs.com/i/ARP/070/100-99...oductId=744898
Old Feb 3, 2011 | 11:59 PM
UBETRUN's Avatar
UBETRUN
The guy that helped rebuild my 496 builds 1700+ HP all-motor billet BBC engines for a living, he used motor oil on the head bolt threads.
Old Feb 4, 2011 | 09:04 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Motor oil is fine if you use stock TQ specs. ARP sealant will do well too. Or GM or any of the other thread sealants.
Be careful using ARP lube though because it is slippier than regular oil and you will need to adjust TQ specs so you don't stretch fasteners. It's best used with their fasteners along with the specs for that lube.
JIM
Old Feb 4, 2011 | 12:48 PM
DO2G's Avatar
DO2G
Cylinder heads
Old Feb 4, 2011 | 01:05 PM
midyearvette's Avatar
midyearvette
.....especially use the washers and thread sealant too.....
To Head Bolt Question
