Air/Fuel mixture help-Lars?
Old Apr 11, 2002 | 12:34 PM
mulchie's Avatar
mulchie
Default Air/Fuel mixture help-Lars?
I just finished timing my motor and having it idling to spec (700rpm). How can I establish a baseline idle from which to begin fine tuning the air/fuel mixture? the procedure is to adjust idle screw until 700 rpm is reached, turn screw in until a 20rpm drop is achieved then back the screw out 1/4 turn. I'm just not sure if the current idle is a good baseline or if there is another procedure I'm missing. The car is a 71 with a four barrel holley. Thanks
