C3 l82
Old Feb 5, 2011 | 07:25 PM
kgchippt's Avatar
kgchippt
3rd Gear
Default C3 l82
I have a 74 L82 Coupe-owned since new. Removed from storage ( 31 years ). Transmission when put into reverse ' slams ' into gear. Forward is OK. Any thoughts as to problem. Thanks for your time.
Old Feb 5, 2011 | 10:06 PM
speedreed8's Avatar
speedreed8
wow 31 years in storage!, automatic i presume, change the fluid and filter to begin with.
Old Feb 6, 2011 | 05:04 AM
hunt4cleanair's Avatar
hunt4cleanair
I agree and in fact would suggest taking it to a dealer than can do one of those power flushes. Its an active flush that pushes new fluid throughout the auto chambers rather than a passive flush where you just drain the pan. Yeah, assuming its an automatic. But if its sat that long, I would flush all fluids and change before serious driving. Especially check those break caliprs for leaks. Sounds like it should be in great shape tho.
How many miles?
Old Feb 6, 2011 | 11:16 AM
kgchippt's Avatar
kgchippt
3rd Gear
How many miles?
Thanks for the reply. 16550 miles ( wifes car ). In the process of fluids/brakes/carburator ect. Power flush vs. gravity is interesting - will pursue checking on.
Old Feb 6, 2011 | 11:17 AM
kgchippt's Avatar
kgchippt
3rd Gear
Thanks for the reply. In the process of fluids/brakes/carburator.
Old Feb 6, 2011 | 12:56 PM
jb78L-82's Avatar
jb78L-82
If it was me, I would try running some Seafoam transmission flush in the car for about 1/2 hour before the actual transmission change-Change the trans fluid, filter and drain the torque converter. I would then run seafoam again in the fresh fluid for about 100 miles and change all the fluid and filter again and you should be good to go. Just my 2 cents!
Old Feb 6, 2011 | 03:11 PM
Will's'74VetteL-82's Avatar
Will's'74VetteL-82
I have seen and heard of this happening before, a fluid and filter change like the rest said should fix it up! Once the fluid is changed take a long drive with it if the car is drivable. It should be good then.
Will
To C3 l82
