1978 L-82 performance mod questions
Old Feb 7, 2011 | 09:32 PM
UCVette's Avatar
UCVette
Default 1978 L-82 performance mod questions
Ok this week starts my quest to get to 300hp. My L82 already has an Accel distributor from previous owner. I am putting on Hedman Headers and new exhaust (cat free) with new mufflers this week. Since I am doing a little at a time, I thought about replacing the stock fuel pump with a Holley at the same time this week. Would that be worth it or should i just wait until the OE goes bad? Regardless, my next plan is to replace intake (Edelbrock) and Holley carb (600 or 650) and then heads and cam.
I would appreciate feedback on fuel pump, carb size, and other obvious things I am missing.
thanks in advance
Old Feb 7, 2011 | 09:38 PM
Shark Racer's Avatar
Shark Racer
Fuel pump won't make a difference as long as yours is in good shape.
I don't think the intake will be worth a whole lot either. If your q-jet is in bad shape and out of tune, the Holley will help some but not much. I'd leave the intake tract alone until you do the heads and cam.
Hell, with an L-82 and full blown headers and exhaust, you should be able to get close to 300 hp as is.
Just verify that the carb and ignition are tuned well.
Old Feb 7, 2011 | 10:02 PM
scottyp99's Avatar
scottyp99
The L82 has the big cam and big valves, free up the exhaust, tweak the spark advance and stock carb, it'll wake right up.
Scott
Old Feb 7, 2011 | 10:08 PM
Scott Marzahl's Avatar
Scott Marzahl
Your Q-jet will flow 750cfm, rebuild it and leave it in place as well as the manifold. A fuel pump is a waste of money. Is that Accel distributor a HEI style? A stock HEI is hard to beat, regardless of which one you use, make sure that your distributor has been recurved to bring the timing in 36 degrees by 3,000 RPM with the vacum hose disconnected and plugged.
Old Feb 7, 2011 | 11:13 PM
macx's Avatar
macx
Just disconnect & plug the vacuum hose while you are doing the timing - hook it back up when you're done.
Old Feb 8, 2011 | 09:23 AM
fauxrs's Avatar
fauxrs
pretty much agree with everything said above.
Fuel pump - waste of money.
Edelbrock manifold & holley carb - not much gain
headers and exhaust - excellent first step.
I read an article about the prepping of the actual indy pace car in 78 (the backup car actually) they said that removing the original highly restrictive factory pellet convertor was worth 25 hp alone.
Headers and duals with no convertor along with a proper tune will get you well on your way to 300 hp.
After that your heads are your next issue, even though they have large valves, they do not flow terribly well compared to , well, just about anything you can buy today, even a set of bone stock low lift vortec heads outflow the original thin wall L82 castings.
There may be some small gains to be had with an edelbrock (assuming performer) intake, stick with the qjet.
Old Feb 8, 2011 | 09:40 AM
78 C3 Light Corvette Blue's Avatar
Acct suspended by request 19 April 2011
There was a thread on this here a while back. Net HP 220 Gross around 313. I believe closer to 320 but why argue over 7 hp. This is stock off the line at GM
Old Feb 8, 2011 | 09:49 AM
jb78L-82's Avatar
jb78L-82
Agree with everything stated above. I have actually done what you are suggesting to my bone stock internally L-82 4 speed. I have a 4175 Holley (25 years now, just rebuilt it myself), stock aluminum OEM intake, zero pollution control, Shorty headers, 2.5 true duals with Monza Turbo mufflers, K&N air filter in the OEM housing, and roller rockers. The engine is sooo much faster than when stock. Forget the intake (and carb if the Qjet runs ok) and do the rest. I am thinking about the heads and cam but probably if the OEM ones crack at some point but I doubt it since the car now runs at 175 degress with the Dewitts aluminum radiator versus the stock temperature of 225-235 degrees which I believe greatly contributed to the head cracking issue. Hope that helps!
Old Feb 8, 2011 | 02:35 PM
7t9l82's Avatar
7t9l82
if you do the timing chain advance the cam timing 4 degrees which the factory did for emissions and it will REALLY wake up kind of like Washington, get the retard out
Old Feb 8, 2011 | 03:50 PM
jb78L-82's Avatar
jb78L-82
How do you advance the timing on the cam? I am putting in a comp cams timing chain and gear set this spring. Thanx.
Jeff
Old Feb 8, 2011 | 04:31 PM
7t9l82's Avatar
7t9l82
all the companies have adjustable timing chain sets no more difficult than a standard set, if you change cams you may just want to install it straight up but the L-82 really wakes up if advanced 4degrees
Old Feb 8, 2011 | 05:46 PM
jb78L-82's Avatar
jb78L-82
[QUOTE=7t9l82;1576739290]all the companies have adjustable timing chain sets no more difficult than a standard set, if you change cams you may just want to install it straight up but the L-82 really wakes up if advanced 4degrees[/QUOT
I don't know anything about adustable timing chains but companies like comp cams sells timing advance shims/buttons that require drilling the timing gears-not that simple. Originally I thought my marks would not be aligned when I take the case off and could just line the marks up for advancement but I guess that is not the case. How exactly did you advance your cam and where did you get the adjustable timing chain?
Old Feb 8, 2011 | 05:53 PM
7t9l82's Avatar
7t9l82
summit racing mine is made by cloyes. the drill and bushing type is more for a pro builder. the adjustable sets are stupid simple. just because you haven't heard of it doesn't mean it does not exist.
Old Feb 9, 2011 | 07:25 AM
jb78L-82's Avatar
jb78L-82
You are absolutely correct-my ignorance and thanx to everyone alerting me to this option. I guess I am surprised that when I searched Summit Racing's website for timing chains, this option did not come up (I found it though when searching for adjustable timing chains). My error and thanx to all of you for the info. Did not mean any foul here!
Old Feb 9, 2011 | 12:45 PM
7t9l82's Avatar
7t9l82
good luck . i beleive you will be very pleased! my 78 with a few modifications would always out run a friends l-82 with a 268 cam! these motors were really under appreciated
Old Feb 9, 2011 | 01:46 PM
USMuscle's Avatar
USMuscle
Do you have a part number for this? I couldn't find it on the Cloyes website...
This is exactly what I am looking for in my 77 L82 350!!!
Old Feb 9, 2011 | 02:12 PM
Scott Marzahl
Either the Street True Roller 9-1100 or the heavy duty True Roller 9-3100 are great timing sets with 2 and 4 degree adjustments.
To 1978 L-82 performance mod questions
Old Feb 9, 2011 | 02:29 PM
pauldana's Avatar
pauldana
Some good opinions.... my question is, are you just shooting for 300.... or are you on a quest to even more hp... like 500-550hp..... power is addictive,.....
imho, if you are on your way to 500+hp, then forward think.... a RPM airgap from Edelbrock would be good, im running a BG Mighty Demon 750.... etc.... dont buy twice, like I and so many others have. The stock carb and intake are fine for 300..... not more.
I would go crazy with only 300hp.... just not near enough fro me,,,, jmho
good luck, Paul
Old Feb 9, 2011 | 03:13 PM
7t9l82's Avatar
7t9l82
500 h.p. from a small block wont be very streetable. people need to focus on what they want the car to do,a500 h.p. engine wont guarantee anything. you can't say a 500 h.p. motor. will make my car go 11.0 it doesn't mean anything! ill beat your 500h.p. car with my 350 h.p. car because its been set up correctly for the combination. a motor is a small part of how a car performs, see where I'm going with this? 500 h.p. doesn't impress me even a little. if your looking for that kind of power this thread is a waste of your time
Old Feb 9, 2011 | 03:27 PM
USMuscle's Avatar
USMuscle
Thanks for the part #'s. Any advise on the difference between the two (besides 3 X's the price!). FYI, I personally am looking for 350 HP at most...
