The Equalizer
Old Apr 11, 2002 | 11:02 PM
Volts's Avatar
Volts
Cruising
Default The Equalizer
Ok, Guys does it matter where the equalizer (H pipe) is located, near the header connection or by the middle of the exhaust system? I have true duals without the H pipe or cats. Looking to get done this weekend but wondering where is the best location of the H pipe would be? I hope it makes a difference to the proformance as I have a 406 cu" small block. :confused: :confused: :confused: :
Old Apr 11, 2002 | 11:10 PM
Chris Fowler's Avatar
Chris Fowler
Cruise-In IV Veteran
St. Jude Donor '03-'10
Default Re: The Equalizer (Volts)
I'm pretty sure the closer to the engine the better, but let someone else answer to be sure.
Old Apr 12, 2002 | 08:39 AM
vettfixr's Avatar
vettfixr
I believe that the closer to the header connectors you can get the better off you are. I've heard that you should paint a stripe along the header to exhaust pipe and put the crossover where the paint stops burning off. Realisticly on C3s you are limited by space. I had mine connected by a shop and they were able to put the crossover just before the crossmember which is about 12 or 14 inches from the collectors. My car is a stick so this might not be possible with an auto.
To The Equalizer
