pulling engine and trans
Old Apr 11, 2002 | 11:07 PM
WHTSHARK's Avatar
WHTSHARK
Default pulling engine and trans
next week i plan to this while i have them out what do u guys suggest i do i plan on doing the front suspension.cam headers, recurve rebuild trans carb and detail engine compartment.anything else? :cheers:
Old Apr 11, 2002 | 11:16 PM
Rockn-Roll's Avatar
Rockn-Roll
Default Re: pulling engine and trans (WHTSHARK)
Check your brake lines where they attach to the proportioning/distribution valve, also clean up and inspect the steering joints.
Old Apr 12, 2002 | 09:02 AM
Gordonm's Avatar
Gordonm
Default Re: pulling engine and trans (Rockn-Roll)
I see you are back on the forum. I would also repair or replace the front wiring harness. Yours had some Bubba mistakes in it. Clutch is also a good idea if it was not replaced earleir. Hmm about 1 million other things if I think long enough
Old Apr 12, 2002 | 09:43 AM
WHTSHARK's Avatar
WHTSHARK
Default Re: pulling engine and trans (Gordonm)
finally! got gack on! maybe if today the sun comes out you can can take a spin over maybe swap some of your parts with mine :D i will be out under my car geting ready for the big operation.
To pulling engine and trans
