Lower horn spring on steering column...something missing
Old Feb 11, 2011 | 09:17 PM
bluegtp's Avatar
bluegtp
Default Lower horn spring on steering column...something missing
When I bought my vette the previous said the horn was stuck "on" so he pulled the fuse. well put the new fuse in and traced part of the problem back the to relay. Now the other part is the lower horn spring (the large 3-4 spring that tapers to a small diameter) keeps grounding out on the column. Is there some kind of retainer piece that should go around the metal column here? Or is there a certain way the spring should be set in there by the horn contacts?
thanks for any help you guys can provide. Diagnosing what's wrong with something when parts are usually missing can be frustrating.
Ryan
Old Feb 11, 2011 | 09:29 PM
...Roger...'s Avatar
...Roger...
Yep your missing the plastic piece. I'll find you a pic.
Old Feb 11, 2011 | 09:31 PM
...Roger...
Here's what your missing.
http://willcoxcorvette.com/product_i...ducts_id=24018
Old Feb 11, 2011 | 10:13 PM
z10kl's Avatar
z10kl
Rogers correct. Mine was the same way. First it wouldn't blow. I replaced the relay. Then it blew all the time. That piece was gone on mine. Bubby had put electrical tape on the spring to fix it.
Old Feb 12, 2011 | 12:33 AM
bluegtp's Avatar
bluegtp
Awesome, thanks for help yet again!...
Would yall happen to know if this a part that is common in older chevy steering columns that I can get locally?
Old Feb 12, 2011 | 08:35 AM
Jim Shea's Avatar
Jim Shea
It is common to all older T&T columns. It is available through GM dealers at a very high cost. It is available through most Corvette suppliers. I do not know if you can find it hanging on the rack in your local auto parts store.
That part (if it is/was original) will break into several pieces when you try and remove it as part of servicing your T&T column. It is best to purchase one before hand when working on a most likely original T&T column.
I was working on my T&T column one Friday night when I broke this part. I did a Bubba repair by covering the locking plate with duct tape and carefully cutting out the brass horn contact areas with a razor blade. This worked until the following week when I could purchase a new plastic retainer/insulator part.
BTW, that part is called a retainer because it covers the c-clip that retaines the upper steering shaft. The c-clip is truly a critical safety part. Without that c-clip the entire steering wheel and upper steering shaft can come out of the steering column right into your hands!
Jim
To Lower horn spring on steering column...something missing
