Weak valve springs will cause a big reduction in power, if all your efforts don't net what you are looking for might be another place to look. 100K on stock springs with high lift cam .
Looks like you are getting a lot of good advice.
A visual indicator of this is to look for chipping at the top of the valve stem. (Guess where the chips go!).
Chas
Thanks I'll add this to the list of things to check...will check into it after the compression test.
One other thing I noticed this weekend is that someone replaced the exhaust with the standard small block exhaust system. The other lt-1 has the correct exhaust that gets wider a few inches down from the manifolds. The slower car doesn't have this, it has the smaller pipes. How big of an impact on performance would this have?
I run Corvette Central RPO N-11 "off-road" set-up on the stocker LT-1. The super fast one has a custom 304 Stainless Steel exhaust system. I know if I put headers and good exhaust on the 70 roadster it would pick-up around 30-45HP but no maintenance issues with the exhust on it right now. I would look up the Corvette Central system if you like a stock looking system that performs well and sounds right.
