Motor will not fire,Just stop while running.
Old Feb 13, 2011 | 07:43 PM
findley87's Avatar
findley87
Default Motor will not fire,Just stop while running.
Can not get motor to run on my 81 vette,Put in new pro comp coil & distributor,this is a 383 motor that been in for 4 years , Did remove the ccc in this car, neever had any problems till now, this is a 4 speed car,Is their something i am over looking.P.S. i put back the old pro com coil & distributor still no fire to distributor.
Old Feb 13, 2011 | 07:55 PM
terry82's Avatar
terry82
is there power to the coil?
Old Feb 13, 2011 | 08:35 PM
joewill's Avatar
joewill
I don't understand, motor does not fire, but does run and then stops?
Old Feb 14, 2011 | 05:54 AM
findley87's Avatar
findley87
yes , their is power to the coil
Old Feb 14, 2011 | 09:07 AM
bashcraft's Avatar
bashcraft
Well, since we have no information to go on except that there's power to the coil, we need to start with the basics. Is there gas in the tank? How about in the carb?
Old Feb 14, 2011 | 09:15 AM
johnt365's Avatar
johnt365
Are you getting fire at the plug? Check that first.
Old Feb 14, 2011 | 08:36 PM
findley87's Avatar
findley87
has 2x4 with tunnel ram, has gas, no spark to the plugs,this motor has been running for 4 years in this vette, and now it stop
Old Feb 14, 2011 | 10:11 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Lots of stuff to check. Broken cam at the cam gear end is a possibility as long as the hot wire to the distributor is good. Does the distributor shaft rotate as the motor is turned over?
Old Feb 14, 2011 | 10:16 PM
Les's Avatar
Les
Have you confirmed that the rotor is turning with the motor? If the gear on the back end of the cam is stripped your distributor won't turn and it would act the way it's acting. If that's OK I'd be checking ignition box and/or the wiring to the distributor.
Old Feb 15, 2011 | 06:53 AM
bashcraft's Avatar
bashcraft
If it has a roller cam it could've wiped out the gear on the distributor. There's hundreds of thing that could've happened.
Old Feb 15, 2011 | 07:59 AM
dogboy's Avatar
dogboy
I'm guessing its an HEI dist system. Check the ignition module in the distributor. Did the new dist. come with one? Mine quit like that & I found one of the 2 wires broke off , No spark to plugs. Dead on the road.
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by findley87
...no spark to the plugs,this motor has been running for 4 years in this vette, and now it stop...
Check your new coil and distributor installation. Based on your posts, it was running before you made your changes.
Old Feb 15, 2011 | 02:12 PM
redvetracr's Avatar
redvetracr
couldn`t be that Chinese distributor could it?
Old Feb 15, 2011 | 04:30 PM
sly vette's Avatar
sly vette
I Don't know if it stopped while running or won't start.
This is the title to the original post....
"Motor will not fire,Just stop while running."
I think it was running and stopped.
Really hard to interpret some of these posts sometimes.
Old Feb 15, 2011 | 07:27 PM
findley87's Avatar
findley87
the roator is turning,it got to be a wire somewere cause i am about to give up
Old Feb 15, 2011 | 07:58 PM
LB66383's Avatar
LB66383
If you disconnect the coil wire from the center of the distributor, hold it near the intake manifold, and crank the engine, do you get a spark?
Old Feb 16, 2011 | 05:49 AM
findley87's Avatar
findley87
no fire to cap.
To Motor will not fire,Just stop while running.
Old Feb 16, 2011 | 10:06 AM
jimboscarbs's Avatar
jimboscarbs
If I'm reading this right??????
Sounds like you only have power to the coil/distributor when the key is in the start position, did you put a remote solenoid on it by chance?
Old Feb 16, 2011 | 10:55 AM
81pilot's Avatar
81pilot
no fire to cap.
Open the cap and check everything. Check the contacts inside the cap and the bug electrodes for good continuity, spacing etc... If it has 12V going to the dist with the key on, and no fire at the cap to the plug wires and everything internally checks out then it sounds to me like a bad module. You said you pulled the CCC, but did you do that before you replaced the distributor? In other words, do you have an old module laying around that is not computer controlled that you could plug in for a test? Or just run down and get one. Its gotta be obvious once you track it down. You also need to check for an open in the coil.
Old Feb 19, 2011 | 03:17 PM
findley87's Avatar
findley87
Put in another distributor that dose not need to be on a msd box, run now, thanks for all the help
