Electric Fuel Pump Wiring
Old Feb 13, 2011 | 09:43 PM
81fixerupper's Avatar
81fixerupper
Default Electric Fuel Pump Wiring
I have an 81 Corvette, which I am installing an electric fuel pump near the gas tank. Looking for input on the best place to get a 12V ignition source for it. All suggestion appreciated.
Old Feb 13, 2011 | 10:54 PM
myoriginal77's Avatar
myoriginal77
Hello,
Run it off a relay. On it's own circuit. Trigger the relay with an ignition on hot wire. Hot from the battery to the relay which will route it to the pump. You may want to put a cut off switch in the line as a safety.
Hope that helps,
Frank
Old Feb 14, 2011 | 07:36 PM
72LS1Vette's Avatar
72LS1Vette
Originally Posted by myoriginal77
Hello,
Hope that helps,
Frank
Pink wires are usually hot in start/run. about using a relay, and the source from the battery should be fused. You can get a safety switch from a junkyard. Ford Taurus and other Ford models have a re-settable switch in the trunk. They will be in great shape even in the junkyard and should only cost a few $. On impact the switch will open and shut the pump off. That should go on the + voltage side also.
Rick B.
Old Feb 16, 2011 | 12:22 PM
Gman6861's Avatar
Gman6861
5th Gear
looking to install a fuel injection system on my 79. any thoughts??
Old Feb 16, 2011 | 12:34 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Yes. Start your own thread.
Old Feb 16, 2011 | 01:14 PM
Mashman's Avatar
Mashman
Starting a new thread makes it much easier for people to answer your question. It also makes it easier for people (who are interested in the same information), to find what they are looking for.
Old Feb 16, 2011 | 01:38 PM
Gman6861's Avatar
Gman6861
5th Gear
sorry, new to this forum.
To Electric Fuel Pump Wiring
