Speedometer Gear
Old Feb 14, 2011 | 12:24 PM
jtramont's Avatar
jtramont
Default Speedometer Gear
The age old question here.....sorry but I've been confused by several of the posts plus what I've read online.
I have a 73 4sp and the speedometer reads 45 MPH when I pass through a roadside radar that clocks me at 35. I realize that they're not 100% accurate but I'm pretty consistently in that range when I pass through any of them in town.
My speedometer gear is a (white) 19 tooth and I've read that each additional tooth will slow down your speedometer by approximately 5 mph which seems to indicate that I need a 21 tooth.
The prior owner removed the stock wheels and installed 255-45R-17's which are roughly 25 1/2" in diameter. Can anyone confirm the number of teeth?
thanks
Jim
Old Feb 14, 2011 | 12:47 PM
78 silver 78's Avatar
78 silver 78
[QUOTE=jtramont;1576789647]The age old question here.....sorry but I've been confused by several of the posts plus what I've read online.
Try this web.site I got mine from here. www.redrider.us/speedometer_gears.htm
Old Feb 14, 2011 | 01:10 PM
Frankenvette's Avatar
Frankenvette
One of the things you did not mention that is important is your rear diff gearing. I have a 3.55 with 17" tires and when I called I was told to get the red gear.. not sure of the teeth count but they said the red one was for 3.55 rear and my 17" tire size.
Old Feb 14, 2011 | 01:14 PM
joewill's Avatar
joewill
Those driven gears are fairly cheap, so buy a 20,21,and a 22 and just try them. its a quick swap out.
my speedo is a little fast with one and a little slow with another. so I can't get it exact..
(assuming my GPS is correct too!)
To Speedometer Gear
