Building a 406 with dart iron eagle platinum 215cc heads and need to know what intake will fit under the hood and still work well with my 406 package.
406 is the same outside dimension as a 350, that being said I have a 406 and run the Dart dual plane, 1/2 carb spacer, holley DP, with a drop low profile edelbrock 14" aircleaner, 3" filter, on my 75. The nut rubs the hood pretty hard. I think your hood is different than mine.
I actually have a brand new RPM airgap I was going to install, but the dart is so close to it I think I will port match the Dart and send the Air gap back to Summit.
Chevy HP magazine Sept. 08 issue, dyno tested 16 small block manifolds and the RPM air gap was great, better than a vitor junior on the top, right with a super victor, really suprised them. It gave port dimnsions though which do not quite add up to what I have on my garage floor. Also gives height dimenstions which may help you out.
You may be able to run the airgap with no spacer, can't do it on the dart, I think my accelorater pump arm hit.
Any way, hope this helps.
The stock 72 hood is a very low hood. The 73 and later hoods actually have more clearance than the early stock C3 hoods. I doubt even a Performer RPM is going to fit. You are very limited in your manifold choices. I ran the LT1 hood on mine and had a variety of intakes, the tallest was the Vic Jr. all of them even with a drop base were right up against the hood. Measure carefully.
L88 hood is the only answer.....Anything you put on to fit under a stock 68-72 SB hood will choke anything bigger then a 350 to death......
MAYBE the old school Weiand Stealth intake will fit, its supposed to be good to 6800 rpms but I think thats on a 350 cid. You really need an RPM air gap or Vic Jr on a 406", especially if its gonna rev to 6k+.
I have a friend with a 383 in a 71 with a stock small block hood.
He is running a Chinese knock-off of the Performer RPM intake.
On his car he has to run a drop base air cleaner with a 2" air filter element to make it fit.
You might take a look at the Weiand Team G, part # 7530. Its about 1/2" shorter than a Performer RPM.
I cant offer any actual experience with that intake, but I would expect it to work pretty well.
Might be a "Professional Products" intake. I run one on my 406 and found the quality actually very good. Casting, fit, finish and runner port size machine consistancy great. I run the RPM airgap clone and found the Pro Prod port dimentions LARGER than Edelbrock. They matched my AFR 215 port MUCH closer than Edelbrock did. All that at half the price.
Eddie
