Engine Hiccup?
Old Feb 21, 2011 | 05:06 PM
czardali's Avatar
czardali
Default Engine Hiccup?
Today is the first day I've driven my car in weeks and after a 2 hour run around town I park my car and the engine does something I can best describe as a hiccup. The car rocked and the engine made a noise as if air was coming out from the carburetor. Does anyone have any idea what this may be?
Old Feb 21, 2011 | 05:22 PM
BHRIG's Avatar
BHRIG
"Run-on", timing might be too far advanced .
It could also be idle is too high or carbon build up.
Try lowering idle first...this is easiest.
Next would be, check timing , retard a few degrees and see if problem goes away.
Carbon build-up has many cures..carb adjustment ..change plugs.....fuel octane...and so on.....
Good luck
Old Feb 21, 2011 | 07:21 PM
croaker's Avatar
croaker
What type of gas you using? Low grade regular? if not that my money would be on your timing to advanced
Old Feb 21, 2011 | 09:43 PM
czardali's Avatar
czardali
im using low grade regular unleaded. I just used Sea Foam today to rid carbon build up. My car does idle really hard. How do i adjust it?
Old Feb 21, 2011 | 09:54 PM
DRIVESHAFT's Avatar
DRIVESHAFT
If your car has a rough idle (assuming thats what you mean by 'hard'), the idle screw may have been adjusted in an attempt to improve it.
Adjusting the throttle blades open too far is the easiest way to induce run on.
Figure out whats causing the rough idle, and you can possibly close the throttle a bit.
Old Feb 22, 2011 | 03:16 PM
croaker's Avatar
croaker
Put some premium fuel in there. Mine does the same thing if I run crappy gas in it only use premium
Old Feb 22, 2011 | 05:37 PM
ghost81's Avatar
ghost81
Navigator
Plus 1 one using the higher grade fuel.
Old Mar 8, 2011 | 11:12 AM
czardali's Avatar
czardali
Fellas! using a high grade gas and adjusting the idle worked! thanks!
To Engine Hiccup?
