Help with headlight bezel
Old Apr 12, 2002 | 08:05 PM
andyg's Avatar
andyg
Default Help with headlight bezel
I wanted to change my headlight bulbs in my '69, but I cannot get the bezel off. The lower water sprayer is holding me up. Do I need to remove the lower sprayer nozzle for the bezel comes out, or is there a trick. Thanks....
---Andy
Old Apr 12, 2002 | 09:16 PM
lbell101's Avatar
lbell101
Default Re: Help with headlight bezel (andyg)
I don't have these but I can see how this might make them difficult to remove. I take it that everything slides forward a bit but the bottom of the nozzle hits the body opening. You may have to pull that nozzle as mine are hard to remove without it. You could also remove the large headed bolt that holds the two parts together and forms a front hinge. Than you could swing the whole top portion up higher.
Then again I've never done this and maybe there is some trick!!
Old Apr 12, 2002 | 10:26 PM
andyg's Avatar
andyg
Default Re: Help with headlight bezel (lbell101)
I ended up removing the lower nozzle. Came out easy. Four new Halogen lights and cleaned up fiberoptics. Never worked so good. Hope she appreciates clean eyes.....:cool:
---Andy
Old Apr 13, 2002 | 10:08 AM
fontking1a's Avatar
fontking1a
You DO have to remove that sprayer. Is there an upper too? If so, remove it also. Pay close attention to the routing of the hoses that lead to the sprayer. Also, pay close attention to the bezel screws and which one goes into what hole.
Old Apr 15, 2002 | 12:09 AM
TQ67's Avatar
TQ67
I just replaced my perfectly good halogens in my 71' with Xenon Replacements.
WOW!!!
The difference is amazing. I probably get 80% more light easy. In addition, the new bulbs are supposed to draw less current than Halogens.
WELL worth the money. :yesnod:
To Help with headlight bezel
