HEI distributor gear
Old Feb 22, 2011 | 01:28 PM
funcouple's Avatar
funcouple
3rd Gear
Default HEI distributor gear
Replacing pick-up coil on 81 350 CID requires removing rotor shaft gear to pull the shaft. There is a drilled detent above the drift-pin hole on "one side" of the gear. Is this an alignment mark ? If so, what is the alignment tech ? My book doesn't show this!!!
Old Feb 22, 2011 | 03:04 PM
mds3013's Avatar
mds3013
IIRC the detent lines up with the contact of the rotor. Ck. This before you remove gear.mike
Old Feb 22, 2011 | 03:53 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
this is also the time to shim the gear if it needs it.
To HEI distributor gear
