Hydraulic roller cam wiped out
Old Feb 22, 2011 | 10:34 PM
vette427-sbc's Avatar
vette427-sbc
Default Hydraulic roller cam wiped out
I finished tearing down my motor the other night and found a few interesting things...
I run a factory style mechanical fuel pump, and when I pulled the cam out, I noticed that the fuel pump lobe was completely wiped out. Im surprised the car didnt starve for fuel.
With a roller cam, should I still do a flat tappet style break-in if I use a mechanical fuel pump? The fuel pump pushrod looked fine, and the pump isnt any crazy high flow style either.
Should I get a different pushrod if I get a new cam?
It seems like it would be easier and only slightly more expensive to get a new cam instead of plumbing in a good external electric pump.
Old Feb 22, 2011 | 10:36 PM
DRIVESHAFT's Avatar
DRIVESHAFT
No break in is required for a fuel pump lobe.
You were most likely running the wrong fuel pump rod.
Old Feb 22, 2011 | 10:41 PM
Gordonm's Avatar
Gordonm
there is a specific rod for a roller cam if I remember correctly.
Old Feb 22, 2011 | 10:52 PM
vette427-sbc
Does the rod have a roller on it? Or just a different material?
Old Feb 22, 2011 | 10:57 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Both types exist, and work.
When you buy a new cam, ask the manufacturer what they recommend.
Also, when you buy a new cam you might want to steer clear of buying another one of Comp's cast iron cores.
Billet rollers are much more durable.
Old Feb 22, 2011 | 11:05 PM
ajrothm's Avatar
ajrothm
And even the billet core rollers may/can need a bronze tipped push rod. Mine did.
Old Feb 23, 2011 | 12:12 AM
gkull's Avatar
gkull
Comp Crap cams require a bronze tip push rod or even a roller tip. Mine mushed the pump lobe and that is when they added it to the directions years ago
Old Feb 23, 2011 | 12:28 AM
vette427-sbc
Yeah they didnt say anything in the instructions when I put mine in.
Rebelrob's Avatar
Rebelrob
Yep, you need a bronze tip fuel pump rod with a steel billet cam. That is what I am using for my roller cam.
Old Feb 23, 2011 | 06:40 AM
73BLWN's Avatar
73BLWN
I'm running Comp Cams Solid Roller 12-704-8 and also ran the 4607 bronze tip fuel pump pushrod. During disassembly this fall I could barely get the fuel pump pushrod out of the motor. Fortunately the fuel pump cam lobe is fine, but the bronze tip sure is wearing fast. I'm wondering how many miles I would get out of the bronze tip, or if it was finally wore in/seated and I shouldn't be concerned.
Old Feb 23, 2011 | 07:55 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
The steel core cams need a bronze tip. The cheaper austempered cast ones will usually work with the stock pushrod. But one with a tip or roller will work on either. The tip one usually does very well on anything.
JIM
To Hydraulic roller cam wiped out
