Won't Start - Safety Switch?
1) Got a 70, 454, 4 speed that was running fine, then all of a sudden won't start. I replaced the lock cylinder and the ignition switch, but it did not resolve the problem. With key on, all wires at the ignition switchs are hot except the purple w/white strip. The two purple wires to the clutch safety switch are not hot at any time. Shouldn't at least one of the wires to the safety switch be hot? Any suggestions?
2) In all the diagrams I have, the ignition switch is comprised of two boxes, one white and one black. My black box has the red and orange wires that the diagrams show. The white box has the pink, purple w/white strip, and brown that the diagrams show, but also has a red wire that the diagrams do not show. Does anybody know what this red wire is for/what it activates?
2) In all the diagrams I have, the ignition switch is comprised of two boxes, one white and one black. My black box has the red and orange wires that the diagrams show. The whisafteyte box has the pink, purple w/white strip, and brown that the diagrams show, but also has a red wire that the diagrams do not show. Does anybody know what this red wire is for/what it activates?
Is the safety cable connected to the steering column in the engine bay? If not, try raising the lever on the steering column all the way up. Any luck?
Ron 1970
and yes i beleive one of those purple wires should be hot.
but its only hot when the key is rotated to the start position
