felpro 1010 head gaskets
Old Feb 25, 2011 | 09:19 PM
Billysvette's Avatar
Billysvette
Default felpro 1010 head gaskets
Does anybody run these gaskets?they are for aluminum heads ,pre flattened copper ring. Are these better to run then like the 1003 pre flattens steel ring gaskets? The 1010 cost more money then the 1003,only difference is the pre flattened ring i think. is it that the copper ring makes less brineling or grove impression into the aluminum? what are you guys thoughts on the 1010 felpros?
Old Feb 25, 2011 | 09:33 PM
Gordonm's Avatar
Gordonm
That is what I have run on a bunch of aluminum headed SB motors. Never had a problem. Not that much more dollars.
Old Feb 25, 2011 | 10:14 PM
Billysvette
What are you running now?
Old Feb 26, 2011 | 01:14 AM
Solid LT1's Avatar
Solid LT1
Stainless rings in 1003 will leave impresion in aluminum cylinder head deck if used. 1010 will not. I now use MLS gaskets on my builds.
Old Feb 26, 2011 | 05:41 AM
Gordonm's Avatar
Gordonm
Still running the 1010 gaskets. I have removed the heads plenty of times with no indents from the head gaskets.
Old Feb 26, 2011 | 10:45 AM
Billysvette
Thank you guys
To felpro 1010 head gaskets
