wiper motor wiring
Old Feb 26, 2011 | 09:21 PM
james53546's Avatar
james53546
Default wiper motor wiring
I am having wiper motor issues on my 72. a few years ago my wiper motor didnt work so i just unhooked it. When i hook up a new motor i get smoking from it. so i checked the voltage on the wires there is 3 wires light blue, yellow and light green wire. I have a wiring diagram. i checked voltage on the wires and on the light blue i am getting bat. voltage on it. should i have that or could it be a bad ground on it. If i bypass the wires and use jumper wires I can get it to work. does anyone know about the blue wire?
Old Feb 26, 2011 | 11:10 PM
Rontech's Avatar
Rontech
Default wiper test
Hi there,
Have you checked the Willcox repair site? There is a wiring diagram at this site. Check it out.
Ron
http://willcoxcorvette.com/instructi...-72_5_2009.pdf
Old Feb 26, 2011 | 11:52 PM
DZRick's Avatar
DZRick
Willcox also has these video's that walk you through testing your wiper motor. I don't know why these aren't added to the tech sticky section.
http://forums.corvetteforum.com/c3-g...d-69-72-a.html
To wiper motor wiring
