Cam break in procedures
Old Feb 27, 2011 | 05:42 PM
Oldguard 7's Avatar
Oldguard 7
Default Cam break in procedures
When breaking in a cam, the manufacturer recommends that the engine must be run at an certain rpm for a certain amount of time. (ie 1500rwpm for 20 min) How does one go about keeping the engine at the required rpms without allowing the rpms to drop? A person's foot would get tired if they try to keep the same amount of pressure on the pedal and afterwhile the engine noise will get to you. So what does one use to keep the engine at the required rpms for proper break in of the cam?
Old Feb 27, 2011 | 06:08 PM
Grumpy 427's Avatar
Grumpy 427
Have a buddy help you out, get it running asap not a lot of cranking. If your alone, take a screw driver and crank the idle up one full to 1.5 turn, that will keep it running till you can get out there and turn it up to where it needs to be. I was told 2000 for 30 min.
Old Feb 27, 2011 | 06:09 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
my hand and then the idle screw
Old Feb 27, 2011 | 06:10 PM
Grumpy 427's Avatar
Grumpy 427
I should ask, is the distributor dropped in close, and are the rocker arms set with the correct preload? did you use lots of cam lube and break in lube etc.
Old Feb 27, 2011 | 08:06 PM
blue427's Avatar
blue427
last time I changed the cam I read the proper way to do it was bring it up to 2500 rpm and vary it to 2000rpm for 30 minutes,don't keep it steady at one rpm.I'm pretty sure I got that info off the forum or Comp Cams website.That cam is still running strong.
Old Feb 27, 2011 | 08:12 PM
jb78L-82's Avatar
jb78L-82
I have read the same from comp cams website but keep wondering how GM broke in the OEM cam from the factory since I know that they did not run new engines at 2-2,500 RPM for 30 minutes to break in the cam. Heck-all they did was start it to drive it off the assembly line. How did they do it from the factory if they did it at all (I don't think so)?
Old Feb 27, 2011 | 08:57 PM
Solid LT1's Avatar
Solid LT1
Back in the olden days, motors were fired off with natural gas and had pre-installation break-in time on them at the motor plant before they were shipped out.
Old Feb 27, 2011 | 09:00 PM
rod7515's Avatar
rod7515
most performance cam grinders want you to run the motor at 2000 - 2500 rpm for 20 minutes. You should vary the rpms as you keep it running. When I did my last one I just sat in the drivers seat and kept vary the throttle. It gets rather boring! Make sure you have your coolant full before you start and watch your gauges. As stated in an earlier reply make sure you have plenty of cam lube when assembled and the oil you are using has ZDDP additive.
Rodney
Old Feb 27, 2011 | 11:10 PM
Oldguard 7's Avatar
Oldguard 7
My question is can the idle speed screw be turned up to the recommended rpms or must you keep your foot on the gas pedal? The reason I'm asking how it is done so when I swap my cam that I break it in right. I did not do this the last time I rebuilt this engine (2004)
Old Feb 27, 2011 | 11:21 PM
redman76's Avatar
redman76
St. Jude Donor '09
Yes, turn the idle screw up to the desired RPM; I used my timing light to set. Had a buddy actually crank the motor and watch the gauges. Had another friend watching for leaks. I followed the cam manufacturer's recommended procedure. Lunati recommended taking up to 3000 RPM for a period of time . . . my neighbor said it sounded pretty good from inside his house.
Old Feb 27, 2011 | 11:49 PM
snoopykissedlucy's Avatar
snoopykissedlucy
Your neighbors are gonna LOVE you when you break in your cam........especially if its at night!
Old Feb 28, 2011 | 01:59 AM
LT1driver's Avatar
LT1driver
my 70+ next door neighbor came over and gave me awhen I broke my 427/435 in with open headers in my garage
Old Feb 28, 2011 | 08:14 AM
nate99's Avatar
nate99
Is this procedure the same for hyd. flat tappet and roller cams?
I'm getting perilously close to being able to fire my new crate engine (flat tappet) up for the first time, so I have to set the timing and everything too. I've got Comp break in oil.
Old Feb 28, 2011 | 09:16 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Some (of us) old guys are very understanding.....
Old Feb 28, 2011 | 09:36 AM
bobs77vet's Avatar
bobs77vet
roller cams dont need the break in since they have rollers....the break in is to allow or "train" the hydraulic lifter to spin on the cam shaft and to promote that wear pattern on the bottom of the lifter....if the lifter doesnt spin you wipe the lobe
Old Feb 28, 2011 | 10:00 AM
nate99's Avatar
nate99
Thanks for the explanation, I had never heard that part before. I do worry about letting it idle (presuming it will) while trying to get the timing set. Hopefully this is a minimal risk.
Old Feb 28, 2011 | 11:36 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
A large fan placed in front of the car will also help simulate air flow so you are not relying on yor engine fan drawing air.
To Cam break in procedures
Old Feb 28, 2011 | 12:06 PM
redman76's Avatar
redman76
St. Jude Donor '09
Just set the timing close enough that it will run and then take it up to the desired RPM for break-in. As long as you lubed everything up real good when you installed cam you should be okay. Make sure to use some good oil with high zinc rating. I used Brad Penn break-in oil on mine -- just a little extra insurance.
Old Feb 28, 2011 | 03:35 PM
nate99's Avatar
nate99
It is a GMPP crate engine that has been sitting who knows how long since it was assembled (at least two years in my posession, don't laugh). I will be priming it and turning the engine over as I do.
Now I'm thinking I might need to get the exhaust sorted before I start it up. 20 minutes with open headers would have the whole neighborhood calling the cops on me.
Old Feb 28, 2011 | 03:57 PM
bobs77vet's Avatar
bobs77vet
did you change the cam in this? if not i am pretty sure the cam is already broken in
