Spark Plugs...
Old Feb 27, 2011 | 06:04 PM
Johan74's Avatar
Johan74
Default Spark Plugs...
For a 69 SB (350hp)...
Zip says R43S
Paragon Corvette Reproductions says R45
and my Haynes manual says R44
Who is correct?
Old Feb 27, 2011 | 07:05 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
R45. For a street driven Corvette the 5 heat range is the way to go on both big and small blocks
Old Feb 27, 2011 | 08:10 PM
SoCalErv's Avatar
SoCalErv
Army
The NGK B4 and Denso W14-U are non-resistor plugs of equivalent heat range to the out-of-production non-resistor AC 45.
Old Feb 27, 2011 | 08:31 PM
Lemans Blue 69's Avatar
Lemans Blue 69
Use AC44S or equivalent. Bought some on ebay. Gap at 33 vs 35 and set dwell to 32 vs 30for best performance.
Old Feb 27, 2011 | 08:33 PM
Mike Ward's Avatar
Mike Ward
For once the Haynes manual is correct, problem is that R44 are out of production and very hard to find.
I like the NGK B4 like Erv mentioned.
Old Feb 28, 2011 | 12:35 PM
Johan74's Avatar
Johan74
Ok thanks.
Removed one of the old ones and they are AC R45S
Will the extended tip do any difference?
If not then why not use R44S and get the correct heat range?
/Johan
Edit: Or is R44S also out of production? Thought that was just R44...?
Old Mar 1, 2011 | 09:29 AM
laktrash's Avatar
laktrash
Where do champion plugs fall into the mix ? I also have a 69 350 with some slight mods. I use to use champion back in the day I did waste some $ splitfire along the won't go back there.
Old Mar 1, 2011 | 01:13 PM
Roughrider's Avatar
Roughrider
I wasted money on Splitfires...nothing but hyped crap. Replaced them with Champions and got good service. Champs, AC and Autolite have always worked well for me over the years, plus a private label made by Prestolite.
I do have to admit an awful lot of car guys and techs I know swear by NGK.
To Spark Plugs...
