Rear caliper mount bracket replacement?
Old Feb 28, 2011 | 11:01 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default Rear caliper mount bracket replacement?
Is it possible to change the rear caliper mount bracket without having to rebuild the bearings?
Old Feb 28, 2011 | 11:33 AM
A88FXRS's Avatar
A88FXRS
yes, remove park brake, four nuts holding bearing carrier and slide carrier off and remove backing plate and caliper support. not too bad to do if all pieces come apart
Old Feb 28, 2011 | 12:17 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I disagree. You need to press the spindle out in order to remove/replace the caliper mounting bracket.
To Rear caliper mount bracket replacement?
