older high compression engines
Old Mar 1, 2011 | 06:00 PM
Scott Marzahl's Avatar
Scott Marzahl
Your '69 350/350 should run fine on 92-93 octane gas. I have basically the same configuration as yours in the 350 I built for my kids 1976. Measured 10.25:1 static compression, 1969 heads without hardened seats and a L79 "151" cam (because thats what I had laying around) verses the L46 cam your engine has. They both bleed off enough compression to result in an acceptable Dynamic compression for 92 octane. I'm also running a tunned Q-jet with some tips from Lars and 36 degrees all in by 3,000 RPM.
Old Mar 1, 2011 | 06:04 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by 694speed350
W I would to like to tune the original engine as I could have done in 1969 without swapping cams etc as I have a # matching engine.
Originally Posted by MikeM
Reading the OP's post, it looks like he's searching for higher octane. Hard to tell. It's also hard to tell why he'd need anymore than 91 or so octane for his engine unless someone has made some unapproved modifications to it!
Originally Posted by Scott Marzahl
Your '69 350/350 should run fine on 92-93 octane gas. I have basically the same configuration as yours in my engine, 10.25:1 static compression, 1969 heads without hardened seats and a L79 "151" cam verses the L46 cam your engine has. They both bleed off enough compression to result in an acceptable Dynamic compression for 92 octane. I'm also running a tunned Q-jet with some tips from Lars and 36 degrees all in by 3,000 RPM.
As others have said, your car should run just fine on straight pump gas. No need for octane boosters, leaded or not.
Old Mar 1, 2011 | 06:38 PM
694speed350's Avatar
694speed350
It does however I burn 93 octaine now have no problems. that is not the point. would like the tereathel lead in the gas for the lub for the valves and maybe to be onery.
Old Mar 1, 2011 | 06:47 PM
Scott Marzahl
You don't need lead for valves, its a wives tale. The only time it does any good is during break-in after a new valve job without hardened seats, the lead works itself into the cast iron. The cast iron itself work hardens very quickly and after a tankful or two of leaded gas the job is done.
Old Mar 1, 2011 | 07:33 PM
Chromie69's Avatar
Chromie69
I am in the same boat as you..I played with the tune of the car for a couple of weeks off and on..I gave up at the point that its as good as it gets..before the fall hit I was driving around town and found some gas at a shell station..I can't remember if it was called cam 2 or not but that sticks in my head..it was 110 octane..after 2 minutes of running the car took off..and had that sweet smell..I had about a half tank and popped another 6 gallons I think in it..I think this may be the best way to get what you want..as suggested on a previous post..mix it or run it straight..I am not sure why the old heads like ours wouldnt need the lead? If they don't have hardened seats then don't the valves pound into the head? I am curious if anyone knows for sure when the seats are hardened from the start..
Old Mar 1, 2011 | 08:33 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Local vette shop buys C12 in 55 gallon drums. One gallon per 10 gallons of 93 pump gas will make your engine happy.
http://www.vpracingfuels.com/
Old Mar 1, 2011 | 09:59 PM
Mike Ward's Avatar
Mike Ward
For the umpteenth time- the valve seat issue does NOT apply to Corvettes.
Old Mar 1, 2011 | 10:33 PM
Chromie69's Avatar
Chromie69
So the corvette has hardened seats from 53 up?
Old Mar 1, 2011 | 11:52 PM
Scott Marzahl
No, GM testing has shown that heavy duty service vehicles that see heavy duty towing and hauling or hard core racing vehicles may benefit from hardened seats.
Induction hardened seats were standard beginning 1973.
Old Mar 2, 2011 | 06:20 AM
Chromie69's Avatar
Chromie69
Thanks Scott..I always wondered about that.
Old Mar 2, 2011 | 09:03 AM
Mike Ward's Avatar
Mike Ward
As stated further up, the hardened seats were first introduced in calender year 1970, so all 1971 and up Corvettes (and other GM cars) had them. The much feared deletion of lead did not cause mass degradation in durability, yet the legend lives on 4 decades later..............
1971-2011, happy 40th anniversary hardened valve seats!
Whooops, my aluminum beanie almost slipped, can't let the aliens read my thought waves!
Old Mar 2, 2011 | 09:32 AM
jackson's Avatar
jackson
Mike Ward:
I didn't see an email addy for you & I don't fool w/ IM etc ...
there's a pleasant site quite near me where Theophilus Ward established a (grain) mill in 1700's; he & wife repose in thicket within a few hundred yards and he was also a Rev war officer ... Ward was a whig, not a tory. Some of the old mill brickwork remains at site. Local Ward plans to submit paperwork for historic site status. There's a small bridge overlooking site ... I manually acquired this GPS from atop that bridge along SC state road S-21-55 (aka Meadow Prong RD).
N 34° 01.761' aka N 34.02936°
W 79° 48.964' aka W 079.81612°
Old Mar 2, 2011 | 01:13 PM
  #33
63mako's Avatar
63mako
St. Jude Donor '08-'09
Why be arrogant, abrasive and confrontational? People ask questions on here to get a straight answer and it is great to share expertise if you have knowledge that applies to their question. No one posts on here to be insulted, degraded or belittled.
Welcome to the C3 section. I've learned not to second guess an OP on a question. My brain is not creative enough to know that they really mean 123 when they ask ABC, I'll leave that up to the guys that have recommended the non-lead containing additives that reduce valve guide wear.
Old Mar 2, 2011 | 02:13 PM
  #34
Mike Ward's Avatar
Mike Ward
How about you get over yourself Mako- MikeM is a long time personal friend.
Edit: Better yet, just block my posts OK?
Old Mar 2, 2011 | 02:24 PM
  #35
Mike Ward's Avatar
Mike Ward
Originally Posted by jackson
Mike Ward:
Thanks for that and I see my original reply from this morning didn't appear, I must have hit the wrong button.
Most Wards in North America came from England, whereas my family came from N. Ireland. The original family name before it was 'anglicized' was 'Mac an Bhaird' which has been traced back to the third century AD and has roots in the word 'bard', a writer or poet. As witnessed above some people don't care for my style of writing and take everything as personal insults and attacks. Guess we know who's lost their beanie, huh?
Old Mar 2, 2011 | 02:38 PM
  #36
63mako's Avatar
63mako
Just pointing out something I regularly notice on your posts that if corrected would make visiting the forum, posting answers, and asking questions much more enjoyable for many members. Think about it.
Old Mar 2, 2011 | 02:47 PM
  #37
Mike Ward's Avatar
Mike Ward
As requested many times before, please block my posts. We'll both feel better (maybe just you) and you won't have the need to monitor or police any of mine. I had honestly thought you finally left the CF and am disappointed you still stick your nose in a create an off-topic unrelated fuss- which has always been your style. Trying to get yet another post locked?
Do you have any on-topic thoughts to share?
Think about it.
To older high compression engines
Old Mar 2, 2011 | 05:36 PM
  #38
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I have one, the tin foil on the head is to stop the government from reading their minds, not aliens.
Old Mar 2, 2011 | 08:57 PM
  #39
694speed350
Still would like to have teraethel additive to add to modern gas. seems the gov is happy to add ethanol why can't I add something else?
Old Mar 2, 2011 | 09:14 PM
  #40
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
<-------- No added lead here.
