Bird cage trim finish
Old Mar 1, 2011 | 01:50 PM
PA14JIM's Avatar
PA14JIM
Default Bird cage trim finish
On the surfaces visible with the T-tops removed the top of the windsheild and such appear to painted black with chrome/stainless showing thru. What should it be or what was it orginally? This is an 77 coupe. Thanks Jim.
Old Mar 1, 2011 | 03:08 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The actual bird cage does not show. You should be seeing trim panels color coded to the interior. In your case, black if you have a black interior. Stainless should be visible in the areas which the trim panels do not cover (windshield header, upper surface of the t-bar). Exterior windshield trim on the 77s is painted semi-flat black.
Here's 68 bright blue; 77 would be similar:
Post a pic of what you've found.
Old Mar 1, 2011 | 03:28 PM
PA14JIM's Avatar
PA14JIM
Ok Easy Mike, that clears it up for me. The outside windshield trim is still black. The top of the windshield where the weatherstrip of the t-top may have be sprayed black by a previous owner. Thanks
To Bird cage trim finish
