odd hazard flasher problem
Old Mar 2, 2011 | 06:08 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Default odd hazard flasher problem
This is not a C3, but I believe you guys are the best to answer any automotive related question. I have this weird problem in a '70 Camaro, all the turn signals are working perfectly, except for the hazard flasher, everything working on all three corners except the front driver, flasher is not working, although it would blink normaly when I turn the signal lever. What do you think the problem is?
Old Mar 2, 2011 | 11:17 AM
IrishJoker's Avatar
IrishJoker
Hazard/warning relay is bad most likely.
Old Mar 2, 2011 | 11:21 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
swap the relay, if that doesn't fix it, check the wiring in the fuse panel, I had a similar issue, turned out the wiring wasn't touching the flashed in the back for the fuse panel.
To odd hazard flasher problem
