In-Dash Lights
Old Mar 3, 2011 | 08:02 PM
USMuscle's Avatar
USMuscle
Default In-Dash Lights
I am doing a gauge project right now replacing back to OEM gauges with white faces. I am looking for some replacement in-dash blue LED lights. Does anyone make this part? Where can I find it and what are the part #'s to fit the different in-dash lights (are they all the same???)?
Thanks!
Old Mar 3, 2011 | 08:54 PM
Denpo's Avatar
Denpo
Thanks!
Found mine on ebay last year.
Most of them can be replaced by BA9S (that the best deal I could find)
For the courtesy lights you'll need ba15s of ba15d depending of the number of connector on the socket (s = single, d = double).
I prefer the smd version, much more powerfull, and I choosed them directional, with only led of the facing side.
They're very bright, not as blueish as I feared for allegedly white led.
You can find some purposely blue, not sure how it would look.
The downside it that you can't dim them. You need a proper led-dimming electronic component installed in the harness.
I can't say more since I've haven't started this part of my project, but it's definitively doable.
Old Mar 4, 2011 | 09:32 AM
USMuscle's Avatar
USMuscle
Are there any cautions to watch out for when installing these such as overloading circuits or anything? Any brands or voltage to stay away from?
Old Mar 4, 2011 | 09:39 AM
U17's Avatar
U17
Does this help ? http://forums.corvetteforum.com/c5-g...od-thread.html
Old Mar 4, 2011 | 09:49 AM
dembo's Avatar
dembo
http://www.superbrightleds.com/cgi-b...ini-wedge.html
Forgot the type nr but can look it up tonight if you want
Nick
To In-Dash Lights
