73-74 & 75 Air Cleaner differences
Old Mar 6, 2011 | 08:18 PM
rcrchsr16's Avatar
rcrchsr16
Default 73-74 & 75 Air Cleaner differences
From all the catalogs I've seen, the 73-74 dual snorkel air cleaner is different than the 75 dual snorkel air cleaner. It looks like the base is a different number, at the very least. What are the differences? I have an L82 73 Coupe that's missing the whole shebang! Thanks!
Old Mar 6, 2011 | 08:39 PM
Phil Zell's Avatar
Phil Zell
I believe it is different due to the HEI distributor
Old Mar 7, 2011 | 10:51 AM
gbvette62's Avatar
gbvette62
The 75 air cleaner needs additional clearance at the back of it, to clear the larger HEI distributor and it's shielding.
The 73-74 base and the ring for the seal, are different from the 75 air cleaner's pieces. The valve cover to air cleaner breather tube is different also. The 73-74 share the same tube, while the 75 uses the same tube as 76-81s. The lid and air cleaner to hood seal, are shared by all 73-75 air cleaners.
It's pretty difficult to tell the differences between the 73-74 base, and a 75 base, without having them side by side. I think the 75 base sits futher forward on the carb, than a 73-74 and the 75 ring, sits further back on the base, to correctly mate to the hood. The 73-74 ring can easily be identified by the 3 notches in it, the 75 ring has 4 notches.
Original bases that still have the AC "Keep your GM car all GM" label on it, can be identified by the code on the label. The 73-74 bases will either have a "DO" or "DB" code, 75 bases will have an "EJ" code.
Old Mar 7, 2011 | 11:37 AM
Mike Ward's Avatar
Mike Ward
The '73/'74 SB adapter rings are different from the BB also. Everybody confused now?
Old Apr 16, 2013 | 07:55 PM
QIK59's Avatar
QIK59
What is the difference between the SB and BB hood seal adapter ring ?
How do you tell them apart ?
Thanks.
Old Apr 16, 2013 | 08:36 PM
Mike Ward's Avatar
Mike Ward
I believe it's the offset to allow for the different carb center to ignition shield distance.
Old Apr 16, 2013 | 08:37 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
My 75 air cleaner has the back of it con-caved in for the clearance of the HEI. As Gbvette62 says its hard to tell the difference without comparing them side by side.
Old Apr 16, 2013 | 09:51 PM
MidShark's Avatar
MidShark
Yeah, the first time I took the air cleaner base off my '75 and took a look at it, I thought somebody had wacked it with a sledgehammer from the back.
Old Apr 17, 2013 | 09:36 AM
KenSny's Avatar
KenSny
The 75 is not offset and it looks like the redesign from 74 was someone using a hammer on the distributor side of the base. Maybe they had to use up all the 74 stock laying around. Looks like a rough fix to me. I do know that base is not offset. A friend of mine found a used 74 and gave it the hammer treatment - Worked just fine. After all if the base was offset then the cowl induction ring to the hood would not be centered.
Old Apr 17, 2013 | 09:56 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by rcrchsr16
...What are the differences? I have an L82 73 Coupe that's missing the whole shebang...
Order the stock 73 set up.
To 73-74 & 75 Air Cleaner differences
