WoW! Throttle linkage problem solved
Old Apr 14, 2002 | 11:32 AM
72Shark's Avatar
72Shark
Default WoW! Throttle linkage problem solved
Had the Q-Jet rebuilt about 6 months ago and the 72 has been running great. Idles fine, driveability has been outstanding. Since I never run it hard I did not realize that only the front half of the carb was being used!! The "post" on the carb linkage was in the wrong hole, so when I floored it, the secondaries were NOT engaged. I moved it to the proper hole and LOOK OUT!! This thing is a monster to hook up in first and keeps them roasting in second!! What a DUMB thing not to realize this earlier. Bad Part?? - Gas mileage is going way down now!!! :cheers:
