C3 Big Block
Old Mar 7, 2011 | 07:05 AM
65396's Avatar
65396
Cruising
Default C3 Big Block
I searched the archives first and came across plenty of C2 answers but nothing for C3's. I'm looking at purchasing a 1970 454 Roadster, the owner has never dropped the tank so there's a possibility something might be there. In the meantime what else sets a BB apart from a SB? It is a numbers matching 454, (restamps worry me), with a big block hood, what are some of the less noticeable items that set a BB apart?
Thanks,
Dave
Old Mar 7, 2011 | 07:11 AM
briaineo's Avatar
briaineo
Tach Redline
You can check on ecklers.com for the correct replacement one:
http://wac.3c1a.edgecastcdn.net/803C.../sku/42170.jpg
Corvette Tachometer, 5500 Red Line, 1969-1971
Reproduction Of Original
1969 427ci/390hp
1969 427ci/400hp
1970 454ci/390hp
1971 350ci/255hp With Air Conditoning
1971 454ci/365hp
Old Mar 7, 2011 | 07:20 AM
nutsy's Avatar
nutsy
rear sway bar. i beleive heavy duty coil springs.
Old Mar 7, 2011 | 07:29 AM
69ttop502's Avatar
69ttop502
U-joint caps on the halfshafts as opposed to straps.
Old Mar 7, 2011 | 10:17 AM
BBCorv70's Avatar
BBCorv70
I'll toss in a few more..
Wider radiator and support, 27 1/2 inches.
Different hood, same as LT1 but with 454 numerals.
Console tag
Old Mar 7, 2011 | 10:20 AM
MrJlr's Avatar
MrJlr
Weight
Old Mar 7, 2011 | 10:32 AM
joewill's Avatar
joewill
http://forums.corvetteforum.com/c3-g...big-block.html
Old Mar 7, 2011 | 10:40 AM
joewill's Avatar
joewill
Originally Posted by briaineo
Tach Redline
1969 427ci/390hp
1969 427ci/400hp
1970 454ci/390hp
1971 454ci/365hp
sorry, but these are incorrect, the correct redline for a BB is 5600.
here's a pic of a correct BB 70 tach
Old Mar 7, 2011 | 12:00 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Any original factory documentation with this car?
Old Mar 7, 2011 | 10:17 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by MrJlr
Weight
A healthy '70 LS5 is far from being the supermasive, impotent lump many are lead to believe, despite the extra pounds over lesser SB's.
Old Mar 8, 2011 | 11:52 AM
BBCorv70's Avatar
BBCorv70
Can't beat the sound they make or the raw torque. I owned a small block fist, then a couple big block vettes. I'll never go back...
Old Mar 8, 2011 | 08:09 PM
John 65's Avatar
John 65
7 leaf spring vs 9 for the small block I believe.
Old Mar 8, 2011 | 08:30 PM
Bob Heine's Avatar
Bob Heine
F41 suspension gives you the 7-leaf. My 72 big block has a 9-leaf and skinny sway bar in back.
Old Mar 8, 2011 | 08:40 PM
65396's Avatar
65396
Cruising
Default Bb
No factory documentation, according to the seller the tank has never been dropped so a glimmer of hope? Someone from the forum will be available on Thursday so hopefully I'll get a better picture. I'm a bit concerned that he says the engine assebmly date and designator are the same sized stampings as the vin sequence.
Anyone ever heard of that? Everyone I've ever seen display the vin sequence much smaller.
To C3 Big Block
