82 Ignition switch problem
Old Mar 8, 2011 | 10:52 AM
RileyC3's Avatar
RileyC3
6th Gear
Default 82 Ignition switch problem
I'm getting a noise from the steering column that I assume is the ignition switch. It sounds like the noise you get when the car is off but the key is still in the ignition (high pitched). I get this while driving down the road (not every time) and also when I turn off the car and remove the key.
It has run down the battery several times. I can jiggle the key and sometimes the noise will stop. Has this happened to anyone else and any ideas on how to solve the problem?
Thank you!
Old Mar 8, 2011 | 03:57 PM
RileyC3's Avatar
RileyC3
6th Gear
Old Mar 8, 2011 | 08:25 PM
terry82's Avatar
terry82
i get no noise from my steering column at any time .i can not think of anything that would make noise in there .try the ignition switch again and listen where the noise is coming from.
Old Mar 8, 2011 | 08:48 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Are you referring to the key left in the ignition warning tone?
Old Mar 8, 2011 | 10:42 PM
81 toy's Avatar
81 toy
thats it
Old Mar 9, 2011 | 09:12 AM
RileyC3's Avatar
RileyC3
6th Gear
It could be the ignition warning tone, but why would it be going off with the key in the ignition and the car running?
To 82 Ignition switch problem
