Help with Holley 4150/4160 CFM600 Accelerator Pump Discharge Nozzle
Hello Brothers,
need your help. I have Holley carb 4150/4160 CFM600 on my 350. Want to buy new Accelerator Pump Discharge Nozzle but don't know which size must be? I found there are few different sizes on holley site ( http://www.holley.com/types/Pump%20D...%20Nozzles.asp ) my is tube type. I thing the old one nozzle spraying not so good. How can I know the size of the old one?
Thanks in advanse
Thanks in advanse
The old one (the one on your car now), will be stamped with a number. Take the screw out, being careful not to drop it down the carb., and pull the nozzle up. Look close and you should see the number on it.
If your car is not stumbling, or hesitating, on take off, put the same size back on. If there is a gasket, make sure to replace it.
Sometimes it looks like one side only dribbles fuel and this is normal. as long as it runs good, it'll be OK.
