Electrical Problem 1970
Old Mar 11, 2011 | 05:37 PM
Rontech's Avatar
Rontech
Default Electrical Problem 1970
Hi Guys,
I need a little expertise. I'm putting the electrical harnesses back in and I have a QUESTION. With the wires connected to the starter, I have 12 volts to the upper battery connection. Are there also supposed to be 12 volts on the R terminal with the purple wire?
Ron
Old Mar 11, 2011 | 07:10 PM
ZZ71S's Avatar
ZZ71S
If you are talking about the purple wire to the little stud to the starter you should get 12v when you turn the key.
Old Mar 11, 2011 | 08:01 PM
...Roger...'s Avatar
...Roger...
12v 24-7 on the large terminal
the R terminal will have 12v with the key in the ON position
the S terminal ,closest to the block ,with purple wire will have 12 v ONLY when the key is in the START or crank position , clutch in or shifter in park or neutral.
Old Mar 11, 2011 | 08:30 PM
Peterbuilt's Avatar
Peterbuilt
Hi Roger, you have PM.
Reguards Pete.
Old Mar 11, 2011 | 09:14 PM
...Roger...
Reguards Pete.
Thanks Pete
The OP ask about the term with wires hooked up.
He also seemed to be pairing the R and the purple which is incorrect.
If the wires are connected and you use a test light.
the R terminal will have 12v with the key in the ON position AND IN THE START POSITION.
If the wire is removed from the R term the R term will only have voltage in the start position.
I didn't go in to detail for fear of confusing what I thought the OP was looking for,test light testing of the terminals with all wires connected.
Old Mar 11, 2011 | 10:48 PM
Rontech's Avatar
Rontech
Originally Posted by ...Roger...
Thanks Pete
If the wire is removed from the R term the R term will only have voltage in the start position. Thanks for the Information. If something else doesn't work I'll be back with more questions.
Pete and Roger,
I have a 4 speed car and Yes I wanted to know with all wires hooked up.
Thanks for the Information,
Ron
To Electrical Problem 1970
