5-speed transmission or diff: Which should I install first?
Old Mar 11, 2011 | 11:55 PM
MN80Vette's Avatar
MN80Vette
Default 5-speed transmission or diff: Which should I install first?
I have a Keisler RS500 PerfectFit transmission and hydraulic clutch kit on order for my ‘80. My diff has been leaking pretty badly from both sides and there is quite a bit of in-out movement on both side yokes, so I decided to have the diff rebuilt while I’m at it. Hopefully the WhileImAtIt disease doesn’t spread much further.
As of last night, the entire drivetrain is out from the block and clutch back. I removed the transmission after I removed the diff with the driveshaft attached. I detached the driveshaft from the diff after the diff was out because getting at the strap bolts above the front diff mount looked like a nasty job. I could hardly see the strap bolts.
The diff will be done quite a bit sooner than the transmission. I can either install it when I get it or wait until the new transmission is in.
Should I install the transmission before I install the diff? Or should I install the diff and then the transmission and driveshaft as though the diff had never been removed?
I’d especially like to hear from those who have already done a 5-speed upgrade.
Old Mar 12, 2011 | 10:14 AM
MN80Vette's Avatar
MN80Vette
Default For those who upgraded to a 5-speed...
Let me put the question a different way:
If you upgraded your transmission to a 5-speed, do you think the install would have been easier if the diff had not been installed?
Old Mar 12, 2011 | 10:38 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I'd put the differential in while I'm waiting on the transmission. Having it in had no effect on my install.
Old Mar 12, 2011 | 11:27 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Did mine together but it wouldn't have mattered. Enjoy the ride! I went from a 4 speed to a 5 speed TKO and from a 2.73 to 3.36 gear. Like driving a different car!
Old Mar 13, 2011 | 12:30 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Keep in mind that if You rotate the Tires with the Trans in newtral You will never have to get to a U-Joint Strap Bolt on top. I probably would of driven the car with the new Trans first before rebuilding the rear, in case You didn't like the Gear ratio. Your 80' should have the 3.07 so it should be OK. You didn't mention what You were doing to the Rear, just Seals or redoing everything including Gears.
Old Mar 13, 2011 | 05:22 PM
Fonz69's Avatar
Fonz69
Put the differential back in and then the trans. later.
I have the TKO-600 and 4:11's and let me tell you its worth it!
Old Mar 13, 2011 | 06:16 PM
MN80Vette's Avatar
MN80Vette
I thought attaching the driveshaft to the diff would be easier with the diff out. I did see how I'd get up in the tunnel to get at the strap bolts, so I pulled the diff back with the driveshaft attached. The bolts had 12-point heads, and all I had for 1/4" 12-point was a box end wrench. The new bolts will be 6-point, so I won't have that limitation.
Apparently attaching the driveshaft with the diff installed was no big deal because the opinion is unanimous: Diff before trans.
Thanks guys!
Old Mar 13, 2011 | 07:15 PM
MN80Vette's Avatar
MN80Vette
I knew that I had a lot of side play in the side yokes and the seals were leaking on both sides. Other than that, I didn't know what else needed to be done inside. I was going to put in a new clutch pack while it's open so I don't have to open it again.
The gears weren't noisy and the 3.07 ratio seems to work well with the RS500 gears, so I wasn't planning to change the gear ratio. Paul (the local Corvette drivetrain expert) named a few other things that often go wrong in these diffs and said he'd replace any of the usual parts that wear.
We discussed all that before he showed me a brand new diff and made me an offer I couldn't refuse. He offered to "cook" and inspect the batwing, mount the new diff, and fill it with fluids for a couple hundred $$ more the cost to rebuild my old one.
Deal!
Old Mar 13, 2011 | 07:54 PM
Fonz69's Avatar
Fonz69
Thanks guys!
Driveshaft
insert in trans....pull back to attach to rear....
Old Mar 13, 2011 | 09:00 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by Fonz69
Driveshaft
This is what I have done when I installed my trans, then later when I installed my new motor. Slide the driveshaft forward into the trans then back to the diff.
Old Mar 13, 2011 | 10:02 PM
72LS1Vette's Avatar
72LS1Vette
Deal!
There are a couple of things that bother me about these statements. First, there are probably no brand new 1980 differentials available, and Second, WTF does he mean by "Cooking" the batwing.
Rick B.
Old Mar 14, 2011 | 08:36 AM
MN80Vette's Avatar
MN80Vette
Driveshaft
Duh. I know that. I'm not concerned about inserting the driveshaft into the trans and sliding it back to the diff. Think beyond that step. I'm talking about connecting the driveshaft to the diff.
Once the driveshaft is slid back to the diff, the u-joint needs to be attached to the diff with straps and two bolts in each. Wouldn't it be easier to attach the driveshaft to the diff with the diff on the bench?
They were sure easier to get them off that way. We just took the straps off the trans end of the driveshaft, and pulled the diff back with the driveshaft attached, set it on the bench, and rolled it away.
When everything was assembled, I could hardly see the straps and bolts let alone get a 1/4" 12-point box end wrench up there with enough room to move the wrench.
So, you guys are saying:
It is easier to attach the driveshaft to the diff with the diff already installed in the car
than to
attach the driveshaft to the diff with the diff sitting waist high on a bench and installing the driveshaft and diff as one unit.
Really? Maybe, if my car wasn't on a lift.
Old Mar 14, 2011 | 08:48 AM
MN80Vette's Avatar
MN80Vette
Rick B.
First, a more accurate description would be "all new". If a part can be replaced with a new part, it's new.
Second, "cooking" was his word for "boiling", like engine builders do with blocks before a rebuild.
Sorry to bother you.
Old Mar 14, 2011 | 09:17 AM
tonyv123's Avatar
tonyv123
I think the easy way to connect the drive shaft to the diff. (with the diff. in the car), is to use a coupla long 1/4" drive extensions (about 2' long), and go at the bolts along side the drive shaft. That way you are beyond the crossmember, and not trying to put a wrench in that little space. You can spin the shaft to get at all 4 strap bolts. Works great, and only takes about 10 minutes or less.
Old Mar 14, 2011 | 09:58 AM
MN80Vette's Avatar
MN80Vette
That makes sense. I just need to buy another 12" extension. Then I can install the diff ahead of time without trying to get a wrench in that small space around the driveshaft-diff u-joint.
Thanks for that idea.
Old Mar 14, 2011 | 09:59 AM
bashcraft's Avatar
bashcraft
than to
You do know that you can spin the driveshaft to get better access to those bolts, don't you?
Old Mar 14, 2011 | 10:38 AM
MN80Vette's Avatar
MN80Vette
Sure, I could turn the driveshaft to get the wrench on each bolt, but working the bolts with a 6" long 1/4" box end wrench in that cramped area sucks. There is more room to wrench ahead of the cross member.
To 5-speed transmission or diff: Which should I install first?
Old Mar 14, 2011 | 12:17 PM
tonyv123's Avatar
tonyv123
I have found that you'll still have to tighten the strap bolts down with the box end wrench, because at the angle you tighten them down (with the extensions & 12 point socket) won't allow you to get a good torque on them. Still under 10 minutes to do!
Old Mar 29, 2011 | 08:36 PM
MN80Vette's Avatar
MN80Vette
Default Diff is in
As recommended, I went ahead and installed the new differential before the 5-speed Keisler.
Here are some pictures before:
Ready to install:
Installed:
Old Mar 30, 2011 | 04:52 PM
Snoopysvet's Avatar
Snoopysvet
Rick B.
Ummm Batwing!
