lower control arm bushings
Old Mar 12, 2011 | 08:55 AM
panicman's Avatar
panicman
Default lower control arm bushings
I am replacing the upper and lower control arm bushings. The upper bushings went smooth however the lower bushings do not want to come out. I have a hydraulic Press and made a spacer to go between the ears of the control arm so it will not smash but the bushings will not budge. Does anybody have any suggestions?
Old Mar 12, 2011 | 10:48 AM
tomgallucci57's Avatar
tomgallucci57
did you drill out the rubber bushing first,it helps to do that.then press it out.
Old Mar 12, 2011 | 11:20 AM
Dave Bureau's Avatar
Dave Bureau
you can press the rubber out and leave the shells. just install new rubber.
Old Mar 12, 2011 | 11:23 AM
jb78L-82's Avatar
jb78L-82
I had the exact smae issue-uppers were easy and put in poly replacements. Could not budge the lower control arm bushings so I just brought them to a machine shop and he did both for 25 dollars and installed the new poly's in about 20 minutes. Well worth the $25!
Old Mar 12, 2011 | 12:43 PM
68-427Rich's Avatar
68-427Rich
Air chisel
Old Mar 12, 2011 | 04:24 PM
panicman's Avatar
panicman
Thanks for the suggestions but I tried all the easy things already. I thought maybe I was doing something wrong. Next come out the torches.
Old Mar 12, 2011 | 05:50 PM
noonie's Avatar
noonie
Once you have the rubber drilled out with ahole saw, then saw thru the pressed bushing lengthwise with a thin sawzall blade and you can knock it loose with a punch without damaging the arm.
Carefull not to saw into the arm itself.
Old Mar 12, 2011 | 06:43 PM
Indiancreek's Avatar
Indiancreek
Use the torch, I use the heat early. Some smoke and smell, but hot rubber is slippery.
To lower control arm bushings
