Calculating compression ratio
Mar 13, 2011 | 12:09 AM
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
What compression ratio will this combination yield?
454 block .030 over, stock stroke, std deck height
TRW L2349 piston
Cast iron GM head #336781 open chamber with 113 cc chamber
Fel Pro composition gasket .039 compressed thickness
Thanks,
Rex
Mar 13, 2011 | 03:44 AM
Mar 13, 2011 | 06:47 AM
Mar 13, 2011 | 09:28 PM
Are you sure on the 781's at 113?
If running a stock deck, use the steel shim head gaskets.
Hope this helps.
Mar 13, 2011 | 10:28 PM
Hope this helps.
Both of these sites show 113 cc, I found another site that says 118 cc.
http://www.minuit10.net/EngineCode/c...linderHead.htm
http://www.nastyz28.com/bbcmenu.php
Mar 14, 2011 | 12:11 AM
With your specs about 10.6, but I agree with trw, the 781s are probaly bigger.
At 118 you'd have around 10.2
Mar 14, 2011 | 01:43 PM
St. Jude Donor '08-'09
CC the heads. Cheap and easy.
115 ,
115cc ,
30 ,
781 ,
cc ,
chamber ,
compression ,
ead ,
head ,
heads ,
l2349 ,
piston ,
pistons ,
ratio ,
trw ,
withopen
