TH400 tranny filter?
Old Mar 13, 2011 | 06:23 PM
retired ralph's Avatar
retired ralph
Cruising
Default TH400 tranny filter?
I put the new filter in and the bolt that holds it on at the oblong hole bottoms out before the metal filter is tight. Did I lose a washer or spacer? Or is it suppose to be a little loose? Thanks Ralph
Old Mar 13, 2011 | 06:29 PM
Rally68's Avatar
Rally68
I don't know about the '67 1/2 & older cars, but the flat "broiler pan" filter on '68 & up will be loose on the center bolt.
Old Mar 13, 2011 | 06:54 PM
mds3013's Avatar
mds3013
I learned this one the hard way. The bolt has a shoulder that tightens up to the valve body and the filter just hangs off by the pickup tube and the bolt, no washer. I use two o-rings on the end of the tube that goes into the trans. mike...
To TH400 tranny filter?
