HELP ! Backfires thru Carb
Old Mar 14, 2011 | 10:53 PM
Derby98's Avatar
Derby98
St. Jude Donor '09
Default HELP ! Backfires thru Carb
So I had my 350 rebuilt. The engine builder dyno'd it ( I was there)
Ran great. He disconnected it from the dyno & loaded it in to my truck,
As I was installing it back in to my car I was careful NOT to mess with anything such as distributor, carb, timing etc.. All I did was connect the transmission & hooked up the exhaust.
I fired it up, wants to start but backfires thru the carb.
I checked for spark & fuel (Both good)
I assumed it is timing related so I rechecked the static timing by going TDC on #1 & the rotor was pointing towards #1 plug wire. I rechecked the firing order & it too is correct.
Refire.......same problem, backfires thru carb.
Am I missing something??
Old Mar 14, 2011 | 11:06 PM
Ironcross's Avatar
Ironcross
check for a intake valve being out of adjustment it could be off its seat on the firing stroke
Old Mar 15, 2011 | 12:15 AM
myk7's Avatar
myk7
Was the distributor removed after the dyno run? How did you find TDC? I agree, sure sounds like a timing problem.
Old Mar 15, 2011 | 07:37 AM
c31980's Avatar
c31980
if the same carb/dist before /after the dyno were not removed ,,then i think you have
a bad ignition switch ,,
Old Mar 15, 2011 | 09:35 AM
Derby98's Avatar
Derby98
St. Jude Donor '09
Really?
But it ranks over fine just won't fire up.
The dizzy was not disturbed in anyway.
Old Mar 15, 2011 | 10:20 AM
bashcraft's Avatar
bashcraft
What kind of distributor?
Old Mar 15, 2011 | 10:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You've got an intake valve open when it ought to be closed. 8 to choose from.
Old Mar 15, 2011 | 11:25 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Sounds to me like a vacuum line / port is not connected. Check them all for a vacuum leak, same thing happened to me with my new 427c I forgot to connect the pcv / brakes vacuum line at the manifold
I think I am going to post this after all my posts. This is not aimed at the OP of this thread but I am tired of helping and getting no response once something has been fixed.
"Please report back what the problem was and how it was fixed "
Old Mar 15, 2011 | 11:33 AM
Jeff_Keryk's Avatar
Jeff_Keryk
As a friendly agreement with MH, it would be benficial to all if OP's would post their results. Most of the time I never know which, if any, solution was the correct one.
Old Mar 15, 2011 | 11:37 AM
SoCalErv's Avatar
SoCalErv
Army
Originally Posted by Derby98
Really?
I thought it ran but back fired through the carb. What is it exactly? Does it run and back fire or will not start now?
Old Mar 15, 2011 | 11:41 AM
bashcraft's Avatar
bashcraft
Read the first post..
"wants to start but backfires thru the carb"
Old Mar 15, 2011 | 02:11 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Since you say the distributor wasnt removed, I bet it got bumped during transport or installation and changed the ignition timing.
That seems like the easiest thing to get out of whack between the dyno and your engine compartment.
Old Mar 15, 2011 | 02:38 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Or the cap got bumped and it broke the rotor. Ask me how I know this.
Old Mar 15, 2011 | 03:32 PM
Kneel 8250's Avatar
Kneel 8250
St. Jude Donor '11-'12
Did you remember to hook up the bypass wire onto the starter solenoid?
Otherwise the engine cranks and tries to fire on 9volts which is not enough and as you let go of the key it backfires up through the carb.
Have a great day.
Kneel.
Old Mar 15, 2011 | 04:25 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Agree with a couple of posters above. My bet is, the distributor cap and/or rotor was cracked during transport,..easily done.
Second bet is the timing was diturbed. Perhaps the bracket that ties down the distributor wasn't fully tightened after you found optimum timing at the dyno.
Third bet is something in the valve train,..stuck valve, broken valve spring (how high did you rev this brand new mill?), etc.
To HELP ! Backfires thru Carb
