69 big block
Old Mar 15, 2011 | 10:37 PM
TOM B1's Avatar
TOM B1
Default 69 big block
I am installing a 454 in my 69, had a 350, I want a larger oil pan.
maybe 8 qts, How big can I go without problems.
Old Mar 16, 2011 | 11:44 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
I used a Moroso 6 qt. pan in my '71 with no clearance issues.
Old Mar 16, 2011 | 11:52 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
What do you need all the oil for?
Old Mar 16, 2011 | 12:26 PM
ajrothm's Avatar
ajrothm
Moroso 20403 is a good fitting 6 qt pan. Clears everything well.
Also Milodon makes a killer new pan that fits BB C3s with better windage control then even the Moroso.
I run the moroso 20403 but can only run 5.5 qts with my 4.25" stroker crank to keep from getting into windage issues and major HP loss.
Old Mar 16, 2011 | 02:26 PM
blively's Avatar
blively
Have any parts numbers for the Milodon?
Old Mar 16, 2011 | 03:36 PM
jnb5101's Avatar
jnb5101
how about a stock L88 pan? it holds 6 quarts.
Old Mar 16, 2011 | 04:27 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Very good option. NHRA Stock Eliminator racers use them a lot.
Old Mar 17, 2011 | 11:17 PM
TOM B1's Avatar
TOM B1
Here is the engine Im building for the 69
I bought a aluminum Merlin X block, all mark 4 compatible. not going to big on the cubes but it will be supercharged, roller cam and fuel injected.
I dont know if I can buy just any BB chevy oil pan or need one built for a 69 vette, and yes 6 qts is enough.
Tom
Old Mar 18, 2011 | 07:26 AM
Fonz69's Avatar
Fonz69
I am running a Stefs pan on my 427 in my 69
Call them up, the guy I talked to had a c3 and sold me the pan with all the goodies inside.
Its a 6q pan
If your running that block this aluminum pan would match it nice!
http://www.stefs.com/stefsindex.htm
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Mar 18, 2011 | 09:59 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
For a 454 the LS-7 arrangement does work well.
For stroker stuff you need more room around the front section to allow oil to get away from the crank. The Milodon 31188 is a killer pan and fits Vette's without P/S...but is close. It will work with Steeroids power rack and pinion though. The equivalent Moroso style drag pan is about a 1/4" too deep in the front and will hit stock drag link.
The pan Alan mentioned would do well on a 454 also.
JIM
Old Mar 18, 2011 | 12:09 PM
68/70Vette's Avatar
68/70Vette
I have the Milodon. Went out and looked and couldn't find a part number. It has outriggers to increase oil volume and internal splash plates.
Old Mar 18, 2011 | 03:02 PM
427Hotrod's Avatar
427Hotrod
Here's the Milodon I'm talking about. It's called the *stepped drag race pan*. What I like about it is that instead of the normal kickouts..it actually has a smaller lower section of the sump. This way any oil that gets back to the pan is higher over the pickup. It also has full length kickout area and a windage tray. I don't really road race with it...but i do get on the brakes pretty hard from 140+ mph on some short dragstrips and I've never seen the pressure fluctuate.
JIM
Old Mar 18, 2011 | 10:42 PM
TOM B1's Avatar
TOM B1
So some steering gets in the way, I better add more info,
I have PS but it it a Borguson Box. this removes the cylinder and valve,
Also updated the suspension to a mono leaf kit in front, dont think this would matter.
Old Mar 18, 2011 | 11:00 PM
427Hotrod's Avatar
427Hotrod
I've got Borgesson on my car and it clears fine. The 31188 Milodon is a relatively deep pan....it comes to the bottom of a scattershield..but above the headers on my car. The only time it's ever hit anything was a giant tire carcass once...but otherwise it's been fine. The LS-7 and above Moroso have better ground clearance if that's an issue.
JIM
Old Mar 18, 2011 | 11:45 PM
Fonz69's Avatar
Fonz69
That stefs pan I have clears the pwr steering on my 69
Here is the last "high" HP motor I built a Dart block 540 making over 1000hp on 9 psi boost and trust me with that nice block you bought do not put any old pan on it
[IMG][/IMG]
To 69 big block
