81 corvette ground cable (dash location) question.
Old Mar 16, 2011 | 12:17 PM
scyzoryk23's Avatar
scyzoryk23
Default 81 corvette ground cable (dash location) question.
Ho many ground cables I shoudl have?
As for now I located one ground cable (on driver side birdcage above kick panel). Do I have anything on passenger side?
S.
Old Mar 16, 2011 | 04:15 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I believe driver's side is the only system ground. Have you checked the AIM? If there is a second on on the passenger's side, the AIM will show it.
Old Mar 21, 2011 | 10:58 PM
elealusaf's Avatar
elealusaf
should also be a ground under A/C controls and towards the firewall that has two screw that hold it to tranny tunnel. i dont know if you are considering that dash?
To 81 corvette ground cable (dash location) question.
