BB intake gaskets
Old Mar 16, 2011 | 02:29 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default BB intake gaskets
Have you ever used these intake gaskets and if so, were you pleased with them?
http://cgi.ebay.com/ebaymotors/Intak...Q5fAccessories
Old Mar 16, 2011 | 03:57 PM
LB66383's Avatar
LB66383
Snake Oil!!
Old Mar 16, 2011 | 04:21 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Dont do it.
Old Mar 16, 2011 | 04:24 PM
MelWff's Avatar
MelWff
get felpro with a blocked heat riser passage
Old Mar 16, 2011 | 05:04 PM
6t9427's Avatar
6t9427
Do you have the Fel Pro part number # ( I am running rectangle port Big Block) ? I have been looking for the block off inserts they didn't come with the Edelbrock gaskets recommended for my new Edelbrock intake.
I would actually like to buy just the block off insert. If anyone can help?
Old Mar 16, 2011 | 06:20 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Those are good if you commonly drop nuts and bolts down your intake, but otherwise
Old Mar 16, 2011 | 08:23 PM
LB66383's Avatar
LB66383
I think the gasket set you want for rectangular ports is the Felpro 1211.
Old Mar 16, 2011 | 09:22 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Try breathing thru a screen and see how difficult it is.
Really It'll suprise you how restrictive it is
Old Mar 16, 2011 | 09:32 PM
Dr L-88's Avatar
Dr L-88
Sort of like a restrictor plate at Talladega??????
Old Mar 17, 2011 | 12:59 PM
centralcalvette's Avatar
centralcalvette
My Bulls**t detector is pegged !! Don't spend all afternoon busting your tail installing questionable gaskets, just use the correct fel-pro gaskets and you're done !
Old Mar 17, 2011 | 04:06 PM
spinadog's Avatar
spinadog
I can see these getting gummed up with crapola pretty quick.
"re-atomize the fuel" - honestly!
To BB intake gaskets
