Brodix IK 200
Old Mar 17, 2011 | 06:34 PM
69vettester's Avatar
69vettester
Default Brodix IK 200
http://forums.corvetteforum.com/phot...medium/084.JPG
I bought these Brodix IK 200's to Go on a GMPP 383 Shortblock. Id forgot about how sweet they looked Right out of the Box
Old Mar 18, 2011 | 09:51 AM
jackson's Avatar
jackson
Have heard rumblings ... that some IK's had VS seals on only intakes ... head foreground in above pic seems to have em on both.
When I heard such complaints ... I wondered if the heads in question had been assembled by Brodix itself; plenty sources selling afr, brodix, dart etc but assembled by independant shop.
Old Mar 18, 2011 | 10:22 AM
69vettester
Please detail what you heard? I bought these heads 4 years ago.
Old Mar 18, 2011 | 10:23 AM
trainor's Avatar
trainor
I installed a set of IK 180 on my small block and instantly had smoking at a warm restart. I spoke with a Brodix tech and he said they do not put valve seals on exhaust side unless customer requested it. They sent me the seals and I put them in. No more smoke.
Old Mar 18, 2011 | 10:58 AM
69vettester
The IK 200's in the Pic were machined By Brodix to use Teflon seals.
Specifically these:
Valve Stem Seal, Teflon®, Positive Stop, 0.530 in. Guide, 11/32 in. Val
ve Stem.
Ive run this engine 30K miles , No oil use, no problems so far. When I rebuild the Heads I will use the teflons again because the head was set up for them. Otherwise I would Look at the Viton type.
Old Mar 18, 2011 | 11:28 AM
69vettester
It can be tricky to install perfect circle style seals , in the case of the Brodix IK 200's , the machining is set up for using PC and the seals function correctly. This would Not be the case if a shop decided to use PC style seals on a generic head. If they dont machine the height clearance for the seal correctly the Seal will be crushed during the first engine rotations.
To Brodix IK 200
