Weather Strip replacement help requested
Old Mar 19, 2011 | 08:52 PM
1980ZZ4's Avatar
1980ZZ4
Default Weather Strip replacement help requested
I have acquired new weatherstrip for the forward and rear side windows and the door to body. I'm seeking advice on the best methods to remove and replace. Additionally, what adhesive do you guys recommend? BTW, this is for my 1981.
Thanks in advance.
Old Mar 19, 2011 | 10:10 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Removal = elbow grease. I am not aware of any solvents that help, however, once the old w/s is off, paint thinner will help remove the old glue.
Install = 3M w/s adhesive is an A+++. Read and follow the directions on the box. Works for me every time.
Old Mar 19, 2011 | 11:58 PM
birdsmith's Avatar
birdsmith
P.S. ...3M weatherstrip adhesive comes in BLACK as well as the standard snot-yellow color...use the black if you can get it.
Old Mar 20, 2011 | 12:24 AM
78IndyPace's Avatar
78IndyPace
Two good articles:
http://www.corvettemagazine.com/2002...ng/seals-1.asp
http://www.corvettemagazine.com/content/view/64/
Old Mar 20, 2011 | 07:35 AM
69ttop502's Avatar
69ttop502
Make sure you wipe the new weatherstrips with rubbing alcohol first.
Bill
Old Mar 20, 2011 | 08:08 AM
Paul L's Avatar
Paul L
Alan71 has a nice write-up (with pics) on this subject.
This is the release agent and glue that you need. Check the former on your paint (out-of-the-way) before using. Normally it is fine but it does not hurt to check.
Old Mar 20, 2011 | 11:48 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
3M cement and remover. The remover works slowly, so be patient. It will not eat paint.
The AIM helps when installing new weatherstripping.
Old Mar 20, 2011 | 08:13 PM
1980ZZ4's Avatar
1980ZZ4
You guys are awesome. Thanks for your comments and support. I'll get the supplies and get busy now.
Old Mar 21, 2011 | 05:07 AM
volition's Avatar
volition
I just did this.. replaced ALL weatherstripping on my 78. It's just a lot of hard labor to remove all the old stuff. I ended up having to use a plastic scraper on a lot of it.
Your doors probably won't close and your windows won't roll up after you put it in. Relax, though. The rubber will "form" within a week or two and everything will be back to normal.
Old Mar 21, 2011 | 08:36 AM
mffi115's Avatar
mffi115
WD-40 to remove the old adhesive.
To Weather Strip replacement help requested
