New Valve Seals
Old Mar 21, 2011 | 06:09 PM
Fastclient's Avatar
Fastclient
Default New Valve Seals
Ok, need some help here. Going to change out the valve seals on the 1979 350. I know there are a couple types and plan on going with the umbrella style (along with the added o-ring???) Anyways they seem to be made of various types of material and some come with external metal bands that say the head needs to be machined to use. Some show the seals with bands with no mention of machine work. Another site said the heads may already be machined from the Chevy. So what has anyone had any experience with and what would you suggest? Also parts numbers would greatly be appreciated. Thanks
Old Mar 21, 2011 | 08:36 PM
'75's Avatar
'75
I used plain umbrella seals and did not bother with the o-rings. Felpro number is SS 10058. I got mine at Napa.
No machining required.
Old Mar 22, 2011 | 05:16 AM
dgood's Avatar
dgood
I changed mine out, used the umbrella seals and the o-rings. Got mine from advance Part No. SS10058. pretty easy change out once I got the right spring compressor. The old ones were all broken up in the heads, and oil pan. They were like hard plastic, guess the original ones were not ment to last 30 years.
Old Mar 22, 2011 | 08:27 AM
Fastclient's Avatar
Fastclient
Thanks guys, with two for Felpro SS10058 I will go with them. Dgood, you mentioned it was an easy fix once you got the right spring compressor, what style did you use?
Old Mar 22, 2011 | 08:39 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
Agreed with above "umbrella type with O rings, I use ether of the spring compressors, one is a long bar type that you screw on the stud, and the other compresses the spring, both are pretty good,Ron
To New Valve Seals
